Fuel Ignition Map for modified LSJ
Old Apr 17, 2018 | 09:09 PM
Medida's Avatar
I am completing the build of a LSJ motor going into a 1986 Lotus Esprit
Upgrades include new POWER BORe Sleeves, Diamond forged 9.5:1 pistons, K1 Technologies forged rods, Total Seal piston rings, Comp Cam stage 2 cams, Supertech upgraded valve springs/retainers/valves, custom headers, larger capacity injectors, TVS, custom intake, LS1 throttle body, ATI Balancer, polished crank and cam journals, return fuel line, aluminum/steel flywheel, all running on MEFI4B controller.
Note: I am using a mechanical throttle body from an LS1 engine, as the MEFI4B cannot control an electrical throttle body
Not looking for ultimate power, just a nice reliable street machine
I have access to an engine dyno but would like to have a good starting map, as Total Seal recommends running at 2000 rpm for 20 minutes for the initial break-in. I would prefer not having to start and stop the dyno while trying to set the engine map
If you have a build similar and would be will to share you map, it would be appreciated.
you can reach me at dlgsmith2@yahoo.com
Old Apr 20, 2018 | 02:18 AM
Medida's Avatar
forgot to add that it also has the dual pass heat exhanger
Old Apr 20, 2018 | 08:00 AM
jdbaugh1's Avatar
Looks like it will be a good combination. I can't answer your question but I wanted to verify that Total seal actually recommends running at a constant rpm for breaking in the rings? That seems strange when everything I have seen about breaking in rings they say the worst thing you can do is hold it at a constant rpm and that you should modulate the throttle, accelerate and decelerate, frequently for the first set of miles. I know total seal are gapless correct? Even being so I find the 2,000 rpm for 20 minutes procedure surprising.
Medida
Oct 12, 2017 04:22 PM
Garrettsi
Feb 14, 2014 03:34 PM
GreenRL
Feb 18, 2010 11:37 AM
GreenRL
ZZ Performance
Feb 17, 2010 02:03 PM
joe_589
Dec 16, 2009 12:22 PM
