fuel milage
But won't running the defrost affect milage? Just like the AC will since it's using the compresser? I guess that makes sense now. Since I always have it on defrost and floor. So I was kinda right.
With the heater on, your condenser is being used to draw any moisture out of the air to be blown on the windshield. To use the condenser, you need to run the compressor. That places a great load on the engine, granted on AC the condenser runs a LOT more.
the newer ac systems shouldent cut but 1 to 2 mpg as long as it is funtioning correctly and not worn out but cold climate will hurt you fuel economy worse then the ac system will
OK. But it does cut down. My MPG drop about 2-4 mpg. All machines are different however. Maybe he has a mechanical issue- with the condenser.
the condenser wont hurt mpg unless it is plug from metal debris from the compressor which would mean his compressor has gone to **** the newer systems realy dont afect mpg much if at all the truck i owned got better fuel economy with the ac turned on
Sl0wbaltSS
Nov 21, 2018 11:11 PM
