Fuel pressure...
Fuel pressure...
What fuel pressure do our cars run at? I have heard through the grape vine they are roughly 68-69psi, but after putting in my SW FPG I am seeing around 48-50 at most at WOT under heavy load. What have you guys seen? Oh by the way I'm new here, welcome. MECP First Class installer on board now for all your electronic needs. Woohoo.
-Christopher
-Christopher
How much horsepower can the stock fuel pump handle? I have the 2.4L VVT Engine.
Are they the same pump as in the SS/SC cars? I am planning on installing a turbo
and am not sure how to upgrade the returnless fuel system. Hoping stock pump will be good enough.
Originally Posted by Jmc007
Fuel pressure is steady at 60 PSI under idle or WOT.
FYI- The official acceptable range specification (from the Fuel System Diagnosis in the FSM) is 50-60 psi (345-414 kPa )
Regards
WopOnTour
Sl0wbaltSS
Nov 21, 2018 11:11 PM
