Fuel Pressure
Old Dec 17, 2007 | 10:59 AM
supersix's Avatar
Fuel Pressure
I couldn't find anything using search. Does anyone know what fuel pressure the stock injectors for an 07 cobalt SS 2.0 opperate at? I am needing to tune a car for the 60 and have a conversion table in excell ready to go but I need to know the stock opperating fuel pressure.
Old Dec 17, 2007 | 12:32 PM
badasscobalt1986's Avatar
there 34lbs i think. i chould be wrong.
Old Dec 17, 2007 | 12:38 PM
Bika's Avatar
Fail Less.
34 lb/hr is the flow rate. the fuel system is pressurized at 58psi static flow
Old Dec 17, 2007 | 12:41 PM
static flow? whats that?
Old Dec 17, 2007 | 01:08 PM
Bika's Avatar
Fail Less.
sorry. static flow was the wrong choice of words.
static flow means not under vacuum or boost. a term used primarily when dealing with vacuum operated return fuel systems. ours has a returnless fuel system, where the pump tries to maintain a constant pressure
simplified answer, our fuel system operates at 58psi
Old Dec 17, 2007 | 01:12 PM
oh thanks learned somthing new.
Old Dec 17, 2007 | 01:17 PM
Bika's Avatar
Fail Less.
no problem d00d
Old Dec 17, 2007 | 02:27 PM
supersix's Avatar
cool same as all the LS1s I tune. Thanks guys
Old Jan 21, 2008 | 05:32 PM
Pickles's Avatar
How would you go about measuring the fuel rail pressure?
Old Jan 24, 2008 | 05:55 PM
Bika's Avatar
Fail Less.
go to autozone, buy or rent a fuel pressure gauge. it threads on to the shrader valve (black cap, on feed line above fuel rail) if you have an ss/sc you need to take off the black rail cover.
Old Feb 3, 2008 | 08:34 PM
Pickles's Avatar
Happen to know if hp tuners will read it?
Old Feb 6, 2008 | 06:32 PM
Bika's Avatar
Fail Less.
HPT wont read fuel pressure at the rail.
Old Feb 6, 2008 | 07:57 PM
Pickles's Avatar
Ok. Thanks.
Do I have to buy one of those full on 300 dollar fuel pressure gauges, or can i buy a unit for measuring the pressure similar to a tire pressure gauge? What I mean is can i get something less elaborate that I can just slap on there while the car is running to make sure fuel pressure is right?
Old Feb 6, 2008 | 08:26 PM
Rodimus_Prime's Avatar
fuel rail pressure is 58psi according to the documents ive seen on gmpowertrain
Old Feb 7, 2008 | 02:36 AM
Pickles's Avatar
Yeah. I know what the rated fuel pressure is, I am just not certain that mine is running there. After tuning every which way, and it still runs scary lean, and really weird. And a buddy of mine has mods very similar to me, and runs really rich.
Old Feb 7, 2008 | 11:42 AM
Area47's Avatar
Rent me! per hour
58-63psi
depandant on the car
Old Feb 7, 2008 | 11:45 AM
06black's Avatar
you can log it in HPT is you wire in an external I/O for a FPS.
58psi is normal pressure.
Old Feb 7, 2008 | 05:00 PM
Bika's Avatar
Fail Less.
my gauge was $26 at autozone.
HPT will log just about anything if you set up an external I/O, but i thought he was talking about having a PID for it.
neo01, what mods do you have and exactly how lean is your afr?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
