Fuel Pressure Gauge
Old Jun 14, 2008 | 11:39 PM
Zach06CobaltSC's Avatar
Fuel Pressure Gauge
Ok. I really really need some help here guys. My buddy Tim and I are trying to install my fuel pressure gauge. We have it all wired up, and the led works etc. However we can not thread the bolt onto the fuel rail.
The stock bolt that came to thread to the fuel rail and then to the fuel sending unit would not fit. So we tried to tap it, and ended up breaking it. So finally we found what we needed.
Basically we need 1/4th on one end and 7/16th's on the other end for them to match up. We found the part, and we lock tite the hell out of the fuel rail valve, and tried to screw it on, no luck. It simply wont go down far enough.
So, I guess monday I am going to have to have a custom bolt made UNLESS the fuel pressure sending unit does not need to be extremely close to the fuel rail valve.
Let me know guys thanks. Hopefully I explained this correctly.
Has anyone ever installed the autometer cobalt series fuel pressure gauge in there 2.0 ss/sc?
Last edited by Zach06CobaltSC; Jun 14, 2008 at 11:39 PM. Reason: Automerged Doublepost
Old Jun 14, 2008 | 11:58 PM
Sharkey's Avatar
iirc most fuel rail pressure taps are -4 an, and most autometer sending units are 1/8 pipe thread. what i would do is get a peice of pre-made -4 fuel/nitrous line, screw that to the rain, then have a -4 male to 1/8npt female for the sending unit, and remote mount the sending unit somewere to the side. you also need to remove the shrader valve from the fuel rail for it to work.
id have to double check the size of the fitting on the rail though, im not 100% sure if the cobalt is the same as everything else.
Old Jun 15, 2008 | 12:41 AM
We did remove the schrader valve from the fuel rail, however we just need to find the right fitting. Hopefully monday we can find exactly what we need. I don't care if I have to have a custom piece made, I just need to know what I need.
So hopefully someone can tell me specifically what I need. I will tell my buddy what you typed, because it will make more sense to him, then it does to me. But I will try and get that part.
Without it, my fuel pressure gauge won't get installed, blah.
Old Jun 15, 2008 | 01:14 PM
has anyone ever installed a fuel pressure gauge in there 2.0 ss/sc cobalt? If so, please post here as I really need some help.
Old Jun 15, 2008 | 10:57 PM
cobalt ss/sc's Avatar
yes i have i'll take a pic and put it in my pics and show you how i did it its -4 to 1/8 pipe thread fitting that u will need and a 90 degree fitting, you put the 90 degree fitting on first then the -4 to 1/8 pipe on that then the sender, without the 90 degree fitting it would be sticking straight up and prob hit the hood.
Old Jun 15, 2008 | 11:00 PM
camarokiller's Avatar
the schrader is probally a NPT fitting, just my guess
Old Jun 16, 2008 | 03:06 AM
cobalt ss/sc hopefully I will be able to tell that to my buddy or to a parts store and they will know what i need, i will try that, and if that doesn't work, then i will have a custom part made. Thanks.
Old Jun 16, 2008 | 05:58 PM
90 degree earls fitting 935104
-4 to 1/8 pipe thread steel- 968704 or aluminum- 998704
no custom parts needed!
Old Jul 23, 2008 | 07:58 PM
CobaltLT's Avatar
Would this be the same fittings to use for a 2.2? I have the same problem with my fuel pressure gauge.
Old Jul 23, 2008 | 11:52 PM
yeah it is the same -4 to 1/8 th inch pipe thread
Old Jul 24, 2008 | 12:33 AM
holy resurrection lol. I remember doing this. It is -4an to 1/8inch pipe thread. its not all that hard mate, good luck.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
