Fuel Rail Help
Old Aug 10, 2006 | 11:46 PM
M88ArRamadi's Avatar
Fuel Rail Help
I just installed INTENSE Stage 4 and now I'm getting wierd sounds from the fuel rails. It sounds like air in the lines.....if that's the case, how do I bleed my fuel system. If that's not the problem, what do I do?......I think this is why i was getting LEAN codes (p0171)
Old Aug 11, 2006 | 02:38 AM
cashstacker's Avatar
the shrader valve on top of the fuel rail just press the little pin in it and it should blead everything. I blead mine before installing the injectors. Also if you have an intake on the might be the cause of it.
Old Aug 11, 2006 | 02:43 AM
Cobalt_Supercharged's Avatar
Don't use the air box mod or a CAI with the Intense kits. That is the cause for your lean code. Get a custom tune to enrich your AFR or replace the airbox.
Old Aug 11, 2006 | 02:46 AM
Ive got a cai with my stage 3 and im still running rich (this is not the case for most)
Old Aug 11, 2006 | 09:27 PM
I took off my fuel rail covers and it sounds like it's coming from my sc!! WTF?
Old Aug 11, 2006 | 09:31 PM
Sounds like you might have a bad blower. See if you can get a stock snout back on it and convert your car back to stock. Then take it in for warranty work.
Old Aug 11, 2006 | 09:36 PM
I doubt the s/c would just crap out the second you got stage 2 on it... I'd try and get a mechanic to look at it before dealing with GM.
Old Aug 11, 2006 | 09:41 PM
I put a Stage 4 w/2.5" pulley on it. We all looked at it and it's coming from the blower. sounds like the routers are bouncing around inside. maybe this will explain the 16 psi instead of the 19+ that I was expecting
Old Aug 11, 2006 | 09:44 PM
Sounds like you had a factory defect and the extra spining caused it to wear faster.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
