Fujita....
Old Mar 15, 2007 | 01:02 PM
S/CSSRedDevil's Avatar
Fujita....
Ok,i just installed my Fujita intake and now my splash gaurd dosent fit back, i actually drove it around witout it on and omggg the sound is REDICULUS.......This thing whines more than my 3yr old nephew, but neways, ne help? or do u think i could possibly leave it off?..thanx guys
Old Mar 15, 2007 | 01:04 PM
CobaltBurst's Avatar
the intake is not fitting right.... you need to loosen your clamps/bolts and wiggle it up higher. If you drive like that in the rain/snow you will suck up water etc...
D4u2s0t's Avatar
if you're giong to leave it off, i would DEF. get a hydroshield asap... the splash guard is what prevents water and whatever else from getting in there so easily.
Old Mar 15, 2007 | 01:06 PM
i dont think the hydroshield would even be enough....
Old Mar 15, 2007 | 01:10 PM
LSJFury's Avatar
Yikes, definitely fudge around with the fitment and get that splash guard back on there. No way would I ever drive without it.
Old Mar 15, 2007 | 01:16 PM
alleycat58's Avatar
Yeah, you've got something screwed up royally, splash guard should fit just fine - I know mine does with the Fujita
Old Mar 15, 2007 | 09:07 PM
ReMz's Avatar
uhhh.... that splash guard should fit just fine. i've had mine on and off 3 times already.
and what are you doing driving around without it???? bad idea. you are going to suck all kinds of things up into that filter.
Old Mar 15, 2007 | 09:53 PM
i only drove around a very small block around my house, i wanted to see what it sounded like....
Old Mar 15, 2007 | 10:01 PM
ninja44's Avatar
The splash shield will not fit back correctly. I was probably one of the first with this intake and it is a known issue with this intake but I've been through 2 winters with it and it will NOT suck up water. The only fix that I know of is to leave the mount inside the fender well unbolted so the intake moves freely and use a 3 inch coupling around the tube where it comes through the fender hole and it may work. I have 2 sets of tubes and Fujita never admitted it was a design error and "forgot" about it. It's the price you pay for a true 3 inch intake and I just learned to live with it. If you like the sound of it now wait til you put a 2.7 or smaller pulley on there
Old Mar 15, 2007 | 10:28 PM
So...u just dont have a splash shield on your car?
Old Mar 15, 2007 | 11:06 PM
ninja44's Avatar
No it's there, it just bulges the liner out and you will get a rubbing sound on extreme right turns and it will eventually burn a hole in the liner.
Old Mar 15, 2007 | 11:12 PM
ook...lol i kinda just wnana leave it off, so much more air gettin to it, prob. dosent sound as loud or as cool if i put the shield back on..
Old Mar 16, 2007 | 01:26 PM
okkkkk...got it on....i just didnt use the bracket that they tell u to use in the direcetions and it was alot easier...
Old Mar 16, 2007 | 01:29 PM
Acidangel_5.0's Avatar
true.. but replace tires with 225/40 it this will go away
Old Mar 16, 2007 | 02:05 PM
alleycat58's Avatar
That's the whole key. That bracket screws EVERYTHING up. Didn't use mine. Intake's been on the better part of a year now. Nothing rubs on the fender, nothing is causing a problem with the splash gaurd, no problems where it drops down into the fender either. The fitment is actually really damn good if you just don't use that bracket.
Old Mar 19, 2007 | 08:20 AM
ok well....first real drive wit it on and not even 5 miles goin to work my CEL comes on...im pissed....should i be worried? im worried my intake like fell apart or something, ne body else have this?
Old Mar 20, 2007 | 04:52 PM
SStud's Avatar
Update on the CEL?? My Injen has a huge slice in it now and i'm looking to either go K&N, or Fujita. Any recomendations from anyone who has had the intakes? Should i stick with injen and just get a new one?
Old Mar 20, 2007 | 04:56 PM
redss05's Avatar
man it seems like everyone is having problems lately with their intakes
