Is g85 worth it?
Old Nov 19, 2008 | 11:02 AM
YzRider452's Avatar
Is g85 worth it?
Hey this winter im buying a ss sc. Does the lsd really help with anything? Should i only buy one that has it?
Old Nov 19, 2008 | 11:04 AM
Altiery54's Avatar
do you plan on auto-crossing it?
btw my cars 4 sale
Old Nov 19, 2008 | 11:09 AM
brandondrecksage's Avatar
if you like to drive spiritedly at all, get a car with g85
Old Nov 19, 2008 | 11:48 AM
Staged07SS's Avatar
Administrator
Administrator
My car isnt a G85, but it launches fantastic with 2 nice even tire marks on the ground. The LSD really helps on an auto cross track like one of the other members said . It's your choice though. If you find a real nice one without it don't be afraid to buy it. The car will still be fast and launch fine.
Old Nov 19, 2008 | 12:06 PM
ddsscobalt's Avatar
how do you know if your car is g85? i have an 07 ss/sc i just bought
Old Nov 19, 2008 | 12:07 PM
ShortStack's Avatar
do you have recaro seats? the g85 package comes with the lsd, and the recaro package seats.
Old Nov 19, 2008 | 12:09 PM
blacksssc05's Avatar
except in later 07 models...my gfs car has lsd and no recaros...
Old Nov 19, 2008 | 12:10 PM
D4u2s0t's Avatar
if you don't have g85, how do you leave 2 tire marks.
Old Nov 19, 2008 | 12:11 PM
red06s/c's Avatar
I dont have lsd and mine also leaves 2 marks
ShortStack's Avatar
^^ Jar Jar Thinks The Same Questions!!! Wwhahbabaahaha...
Old Nov 19, 2008 | 12:12 PM
ggarcia86's Avatar
equal length drive shafts and enough power make it possible to still leave two tire marks, without an LSD
ShortStack's Avatar
i think the lsd redirects power.. if the left loses grip, it puts more power on the right wheel, and vice versa.
Old Nov 19, 2008 | 12:13 PM
D4u2s0t's Avatar
that doesn't make sense. with the open differential just one wheel will spin.
ggarcia86's Avatar
in addition to both tires having equal traction
ShortStack's Avatar
But... i dont know...
ls1fbody's Avatar
Haz l33t wheelz.
^misconception, the LSD does not necessarily have Recaro's, it depends on the year.
LSD keeps the inside wheel from lighting up in a sharp turn, i would recommend getting it because this car was designed to handle well, not just to go fast in a straight line. the LSD keeps the traction high in a turn allowing you to keep you speed up. very worth it.
To find out whether or not you have the G85 package, check under the trunk carpeting on the left side, there is a label with all the vehicle options codes, and G85 will be on there if you indeed have it.
Old Nov 19, 2008 | 12:14 PM
D4u2s0t's Avatar
the car only puts power to one wheel without lsd. it doesn't put power to both. that's why they make an lsd, so that power gets to both wheels vs. 1
Old Nov 19, 2008 | 12:15 PM
red06s/c's Avatar
I kno my car dont have it and it leaves 2 marks. Theres a thread on here about it and a non-lsd car will leave 2 marks.
ls1fbody's Avatar
Haz l33t wheelz.
like someone said above, with equal length drive shafts and enough power, you will still leave 2 tire marks. I don't have an LSD, but you better believe that it leaves to perfectly equal tire marks.
In a straight line on a FWD car, an open diff shows almost no difference from an LSD. in the turns is where you see the benefits.
Old Nov 19, 2008 | 12:16 PM
ShortStack's Avatar
thanks for the fix there, ls1...
and... i had no clue about the trunk carpeting.. lol..
Old Nov 19, 2008 | 12:19 PM
ls1fbody's Avatar
Haz l33t wheelz.
np man.
Old Nov 19, 2008 | 12:23 PM
SSdan's Avatar
Kev the non lsd cars spin both wheels until one loses traction in a turn.
Old Nov 19, 2008 | 12:28 PM
ggarcia86's Avatar
it puts power to the one with most traction, which i beleive usually would end up spinning the shorter driveshaft while the other wheel does nothing, but with equal length drive shafts, and equal tractionboth will spin
Old Nov 19, 2008 | 12:32 PM
YellowBalt06's Avatar
Yeah i would get the g85 just for the racing seats lol
Old Nov 19, 2008 | 01:02 PM
Staged07SS's Avatar
Administrator
Administrator
In a straight line an open diff will still leave 2 tire marks. The LSD helps when you are cornering and one of the wheels starts to loose traction it spilts the torque to the other tire. I have a late model 07' without recaros and i even looked at the build sheet in the trunk under the mat. I don't have a G85, but in a straight line i have always left 2 even tire marks on the pavement.
