gas
Old Nov 19, 2007 | 09:29 PM
killah_thug08's Avatar
gas
i have a ss/sc and im completely stock, now i use sunoco 94 oct and notice my gas goes down very fast or i get around 10.7l/100km or run about 400km on a full tank and i DO NOT drive hard at all, now is it the gas i use or what? if im stock should i use 91 oct instead and would i see better fuel usage
Old Nov 19, 2007 | 10:21 PM
Red07Coupe's Avatar
Canada
There are so many variables to consider when your talking fuel consumption. I would say that if you keep driving the way you do now, even though you don't drive hard, the fuel consumption should stay pretty much the same. If you switch to 91 it will just be a bit easier on your wallet. In fact, 94 theoretically should last longer because it has a bit higher of an octane rating.
Old Nov 19, 2007 | 10:25 PM
JMH's Avatar
JMH
Your milage figures are about the same as mine, so that's not going to change. You probably do a lot of stop and go driving in southern Ont.?
91 octane is what's recomended for a stock SC. I ran it before my stage 2 was installed and it was happy. I now run 94 or 92 (depending on where I am), and there is no noticable difference in the way the car runs. The octane rating of gasoline has no bearing on its potential energy. The higher the number, the higher the temperatures needed to ignite the mixture fully and efficiently. Thats all. So save your money.
betterthanbad's Avatar
Hey there Scarborough............I lived there most of my life!!!!! If you have a new SS/SC it might be a while until your car calms down and gives you a little more bang for your buck!!!
Old Nov 19, 2007 | 10:28 PM
campo165's Avatar
it totally depends. in united states terms, and i specify since i think we are the only country using this metering, i get about 21mpg city. I average 26 mpg city/highway. pure highway i get about 32mpg. i dont care to translate, but if you want, translate. also remember that i live in flat florida.
Old Nov 19, 2007 | 10:30 PM
so i should just switch to 91 to just save up gas for now till later
Old Nov 19, 2007 | 10:36 PM
I have never used anything other than 91 to 94. It's just better for the car to always use premium gas. I will tell you that your performance is greatly improved by using 94.
Old Nov 19, 2007 | 10:39 PM
JMH's Avatar
JMH
Yes, switch to 91. It's all that it needs/wants anyway.
Some time ago I posted a paper on Octane. Unessesarily running hi-po when it's not required isn't only expensive, it bumps your emitions (hard on your cat), it gums-up cylinder walls and fouls plugs.
Old Nov 19, 2007 | 10:57 PM
D4u2s0t's Avatar
using the incorrect octane, whether too high or too low will affect your gas mileage. if you're stock there's no reason to be using 94.
Old Nov 19, 2007 | 11:00 PM
KillerBee's Avatar
i have herd that 94 octane has a touch of alchole in it i am not sure just what i herd i have a lot of mods and only use 93 and get great gas milage
Old Nov 19, 2007 | 11:06 PM
12eha13's Avatar
if ur doin city drivin..then 400 sounds right....i live in scarb too, and recently ive been doin alot of city drivin and i went from 500km per tank to 400..and i have an ls and put bronze in
Old Nov 20, 2007 | 03:42 PM
im gunna try 91 for the heck of it to see
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
