getting some knock on interceptor..
Old Jan 3, 2011 | 10:22 PM
Render2009's Avatar
im trifecta stage 3 and at higher rpms my interceptor starts detecting knock.. how bad is this? also what do certain numbers mean when it comes to knock.
Old Jan 3, 2011 | 10:54 PM
cli3e0339384398jk's Avatar
high rpm knock is the worst u can see, any knock isnt good up top, what are you seeing
Old Jan 3, 2011 | 10:59 PM
Chevycobaltss3's Avatar
Ha ha ha sorry..... its callled winter gas get a winter tune. And call it a day. U might have to wait 2 weeks for a revised tune tho waiting for vince.......
But kr is bad no matter wut... detonation by bye.motor..
Old Jan 3, 2011 | 11:00 PM
DEZZIE41's Avatar
subd so when is a good time to get a tune cause ill be dribing my car that is stage 3 with meth year round
Old Jan 3, 2011 | 11:01 PM
Old Jan 3, 2011 | 11:02 PM
U need to revise ure tune as much s u can I say every season due to climate change but if u can't do it twice a year once in sprin and then late fall when temps are.low.
Old Jan 4, 2011 | 12:09 AM
InfraRedline's Avatar
easiest way to avoid knock in cold temps is to not go WOT. Or get a revised tune like mentioned
Old Jan 4, 2011 | 01:05 PM
383_Stroker's Avatar
Or up the meth mix.. or put on a larger pulley for winter.. not ideal.. but if you can't tune, it'll get you by
Old Jan 4, 2011 | 01:09 PM
ecot3c inside's Avatar
fill your meth tank with hot whiskey.
Old Jan 4, 2011 | 02:37 PM
PenguinPIE's Avatar
are you using 93+ gas?
Old Jan 4, 2011 | 03:08 PM
Bluelightning's Avatar
Got Bewst?
I am running my summer tune in my car and get knock at WOT right now. So i just don't rip on my car. No point in -20 degrees celsius anyways lol.
Old Jan 4, 2011 | 04:42 PM
Render2009's Avatar
I'd say 3/4th of my tanks I get are 93 everyone and then I have to get 91
Old Jan 4, 2011 | 06:05 PM
I have never seen any knock on my ss, even when I do a WOT pull in colder weather, even in a higher gear pull ect., never ever ever and thank god I don't, but I'm on e85 so it's a bit easier not to knock, "knock on wood"
Old Jan 4, 2011 | 06:08 PM
Render2009's Avatar
i just need a REAL tune haha. o well ill wait till summer to see if i wanna turbo swap or tvs.
Old Jan 4, 2011 | 06:14 PM
Staged07SS's Avatar
Administrator
Administrator
Although all winter gas is crappy, always make sure to fill up with 93 octane when running the GMS3 tune. The GMS3 default tune requires 93 octane fuel unless you had Vince tune you for 91 octane. Why do you only get 3/4 of a tank of 93 & then fill the rest with 91?
Old Jan 4, 2011 | 06:26 PM
Render2009's Avatar
as in 3 out of every 4 tanks.. the town i live in only has 91 and when i fill up usually im in another town that has 93 but sometimes i have to use 91
Old Jan 4, 2011 | 11:58 PM
Staged07SS's Avatar
Administrator
Administrator
I got ya.
Well, just take it easy on her druing the winter months and you should be fine.
Old Jan 5, 2011 | 12:00 AM
yeah make sure not to go wot at all and dont punch throttle to even like 60% because your stock mapping sstem is off by prob 15+ or 15- just saying. when you tap the throttle it goes to ve so whenever it does what ever your ve is set to itll do it. be safe
Old Jan 5, 2011 | 12:06 AM
Dr.Balt407's Avatar
im in florida so it doesn't get as cold as other states but rarely i see 1 maybe 2 degrees of knock but thats not bad, i still floor it and so far so good but if you see anymore than that and when your in wot and the interceptor is reading knock all over the place just let off. your best bet is what everyone else says, get a tune for winter and the summer and you'll be fine*
Old Jan 5, 2011 | 12:09 AM
if you see a .00000000000000000121200012102102120120120120 kr at wot let off, its called detonation and you can say bye bye engine and hello out of pocket expenses
Old Jan 5, 2011 | 12:22 AM
Dr.Balt407's Avatar
ive seen 1.0-2.0 degrees of knock and noting happened....but then again im turbo swapped and im only running 15* of timing "shrugs"
but! everyones car is different and so are the tunes. no one really knos whats going to happen to another persons car unless your the one who tuned the thing.
Old Jan 5, 2011 | 12:34 AM
yeah ive tuned umm i thnk like 66 balts now and if you have -9 timing up top and your getting kr there is a reason, from it being either a cracked lash adjuster to a pigment of the imagination, somthing is wrong so if any kr is seen fix it, since your turbo swapped and your getting kr, look at the tune. i can promise you it is this like what is your wot afr, how far is your maf and ve of, are you sure your running 15* up top datalogging. verify all is good liek say your ve and maf arent off, and you checked gap on the plugs and they are ngk s, and you still get kr, check fuel pressures, and check your injectors, if you still get kr, look for somthing loose, if nothing look and listen for somthing inside the engine bay that could possible give you your issue, if nothing gas, compression ect. i mean any kr is bad because it causes detonation stay away from it
Old Jan 5, 2011 | 12:40 AM
Dr.Balt407's Avatar
i kno my tuner and i kno the basics of whats going on. im on 15* of timing all the way and like previously stated its once in a blue moon when i see knock. knock is bad yes but 0.5-1.0 is not going to kill you, ive seen balts blow up with no warning at all but your right about one thing, my plugs are ngk bkr7e's but they are waaaaay over due for changing but ill get to that one day. my car is running just fine and the tune is just fine. kthanksbye!
Old Jan 5, 2011 | 12:41 AM
insylem's Avatar
Ive romped on mine, and my KR SOMETIMES will jump to 2 or even 7 for less then one second, then while STILL WOT it goes to 0.0 and there it stays.
Old Jan 5, 2011 | 12:43 AM
ok if you get kr that means it needs to be retuned or bad gas if you verifies everything else was ok no joke, so with me saying this get yuh shiz tuned lol
