gm stage 2 problem? help?
Old Jul 31, 2010 | 03:31 PM
kyle1853's Avatar
ok so first question is what is the factory stage 2 boost suppose to be? second question will follow accordingly
Old Jul 31, 2010 | 03:34 PM
3de3gre33dk3's Avatar
Stage 2 on the SS/SC is 15psi
Old Jul 31, 2010 | 03:46 PM
kyle1853's Avatar
alright well mine is runing like 12 to 13.....compression good...bypass valve actuator is new and bypass valve is new also.......has anyone seen this.....p.s. i have had my car 3 years in same area ran the correct boost up till now
Old Jul 31, 2010 | 03:48 PM
2FaSSt4U's Avatar
What were you boosting stock
Old Jul 31, 2010 | 03:52 PM
06G85's Avatar
Yes, stock is around 12-12.5. Stage 1 is the same psi, stage 2 should be around 15.
Old Jul 31, 2010 | 03:54 PM
kyle1853's Avatar
Old Jul 31, 2010 | 04:28 PM
2FaSSt4U's Avatar
Did they re-flash it and install the pulley lol
Old Jul 31, 2010 | 05:11 PM
06G85's Avatar
They may not have installed the pulley. If they didn't install the tune it would run like ****. Stage 1 and 2 both have the same reflash
Old Jul 31, 2010 | 07:39 PM
joshcsepegi's Avatar
outside temp And belt slippage iddler pulley bad, did you change anything in ur exhaust?
Old Jul 31, 2010 | 07:53 PM
ecot3c inside's Avatar
oh god, not this again....... There really is no set "boost" corresponding to stage kits, It is different at different sea levels, climates, blah blah blah. boost is a measure of restriction. changes in any modification may lower your boost.. especially exhaust system.
12-13 is pretty damn close to the marked 15psi, I would say you are good.
Old Jul 31, 2010 | 08:01 PM
Berto09ss's Avatar
16psi
at least that's what my old would hit at WOT
Old Jul 31, 2010 | 08:06 PM
I guess that means no one understands...
OP if its any consulation Im in chicago (next door) running a 3" pulley with a slight better tune and I am only hitting 14 psi.
Last edited by ecot3c inside; Jul 31, 2010 at 08:06 PM. Reason: Automerged Doublepost
Old Jul 31, 2010 | 08:10 PM
doober321's Avatar
I'm stage 2 hitting 16 psi on wot
Old Aug 1, 2010 | 02:49 PM
395 plus's Avatar
I do! I have a stage 2 but a 2.9 pulley and hit 14 psi at wot but with extrude honed header and 2.5" exhaust so I have a bit less restriction keeping my boost lower.
Old Aug 1, 2010 | 08:11 PM
Nighthawk243's Avatar
The 15psi number assumes you're otherwise stock. If you have an exhast or intake installed, then it will likely differ. Also, 15PSI goes back down to stock numbers near the redline as a protection feature.
Old Aug 1, 2010 | 11:40 PM
kyle1853's Avatar
well it always did 15 to 16 psi ...then it i had the 2.8 on and it did 18 to 20 ....then i wanted to take it in for some warranty work....leaky valve over so i switched back to the stage 2 pulley and it was running less boost.... so i switch back to 2.8 and it was only running 15 to 16 so i put it back to stage 2 again....found out there was some problems....like i had a bad bypass valve actuator so that was replaced and it boosted about 14 to 15 ...then it started going down in boost like 13 ...so i had a bad cat....took it in ....replaced now 14 to 15 again ..still a little low for what it use to be but i could deal with that...its humid out....now 12 psi!!..13 tops on a good night.......and tonight i dont know if its right or not but i have intake and catback...gmpp.....and i cobalt that was stock...catback and header and tune only was almost dead even with me....idk if thats normal or not...but i still dont know about the boost....and every now and then my car hesitates in second wot....but no light no knock..nothing!??? help?!?!?
Old Aug 2, 2010 | 12:59 AM
Here's a thought, open your H/E fluid cap and see if the fluid in there is actually moving. Could be possible your pump died and the IAT's are going up, causing the engine to back off.
Old Aug 2, 2010 | 01:04 AM
corey_osu10's Avatar
win. been there done that
Old Aug 2, 2010 | 03:22 AM
kyle1853's Avatar
Na, had that replaced, that went out and the car wouldn't even go above 120, ran like complete ****
Are you talking about the actual plug on the heat exchanger it the fill cap?
Old Aug 2, 2010 | 07:39 AM
Staged07SS's Avatar
Administrator
Administrator
No one can tell you what the exact GM Stage 2 boost is supposed to be. GM claims 15 psi, but everyones boost levels will be different. Modifications, location, elevation, temp will all play a part on your boost levels.
Also, boost is a measure of restriction. Higher boost levels do not always mean you are making more power. Remember that !!
Old Aug 2, 2010 | 08:38 AM
kyle1853's Avatar
well do you think a stage 0 with header exhaust and a street tune should run side by side with me and i have cat back and intake and gm stg 2?
Old Aug 2, 2010 | 08:43 AM
Staged07SS's Avatar
Administrator
Administrator
If the car has a good tune then yes.
GM Stage 2's tune is very conservative. If you race a stock pullied/bolted car with a good tune there is a good chance he could hang with you.
Old Aug 2, 2010 | 08:21 PM
kyle1853's Avatar
ok its official!....today now my stage 2 is only hitting 11 to 12 max psi....this is what i use to hit when i was stock??? something has to be wrong? any thoughts!!!! help me
Old Aug 2, 2010 | 10:26 PM
ULWizSS's Avatar
Only had my SS/SC for a little over a week. I am stage two and hit 15 on mine. Sometime it does range between 13-15 but never anything less and mostly always 15.
From what i understand though lots of people are hitting different psi. Would assume it has something to do with outside factors.
Old Aug 2, 2010 | 10:57 PM
xxxxsh4d0wxxxx's Avatar
I hit 13psi at WOT 2nd.. I've seen 14 some times if it's cool enough.
Temperature outside is a HUGE factor, as well as altitude. The Chicagoland area around this time of the year is muggy as ****.
