Gm Stage 3?
Old Jun 19, 2008 | 12:13 PM
blazinbaltss's Avatar
Question Gm Stage 3?
Allright guys i have narrowed it down between gm stage 2 and gm stage 3 jus for the fact im going with warrenty well hears the thingi like the gm stage 3 thats what i want but i heard u have to have gm stage 2 first what way can i get around that. Is there a way?
Old Jun 19, 2008 | 12:15 PM
EXsoccer1921's Avatar
3 isn't warrentied. "offroad use only"
Old Jun 19, 2008 | 12:18 PM
RuSSo-29's Avatar
No, no way around it... Stge 2 comes with the Injectors and Belt you need. THe only diff is the flash's, and Stg 3 comes with the 2x pass
Old Jun 19, 2008 | 12:29 PM
so how much does it cost all together
Old Jun 19, 2008 | 12:31 PM
RuSSo-29's Avatar
Oh also, you lose your A/C with stg 3... I'm sure U know that being as U were deciding between the 2... Ummm $$$... YOur looking at.. around $420ish for stg 2.... and I know CED had the cheapest price on stg3 last I remember looking...
CED = Crate Engine Depot
LamboW9's Avatar
GM stage 3 is not covered under warranty....the GM stage 3 upgrade runs a good penny
BCobaltSS's Avatar
For the GM stage 3 set up or the Stage 2 ?It's hard to find a dealer that will install the Stage3 because it is "off road" use only.
Old Jun 19, 2008 | 12:33 PM
RuSSo-29's Avatar
Yea, around $500ish if I remember....so Give or take $900 w/o install...
Better off going stage 2 and getting supporting mods, and calling it a day... my $.02
lol, yea, OFFroad use, and the fact that the 2x pass seems to be a PITA to put on!
Old Jun 19, 2008 | 12:35 PM
LamboW9's Avatar
^pretty much..bsides if your worried about the wrranty.then your only option is the GM Stage 2
Old Jun 19, 2008 | 12:37 PM
is gm stage 2 still pretty quick
Old Jun 19, 2008 | 12:39 PM
RuSSo-29's Avatar
YEA! I've never really heard any1 not surprised with how sweet it is.. I had the stg2 till I got tuned... Its pretty sweet. and the stg3 after stg isn't that worth it.
Stage 2 FTW!
i dunno its to hard to choose like so basically the stage 3 for zzp is the same as stage two but a smaller pulley
Old Jun 19, 2008 | 12:52 PM
LamboW9's Avatar
ok...GM Stage 2 is identical to the zzp stage 3 in performance...what makes the zzp stage 3 better is as follows....zzp makes seperate pulleys so if you wanted to drop a pulley size then its no problem to get another one that will fit your hub....the 42lb injects come with a seperate wiring harness that will fit the 60's also so if you wanna upgrade to the 60lb injectors later, then you won't have to get a harness (Gm stage 2 injectors fit factory injector harness)....and the tune for the zzp stage 3 is included in the price
if you want to keep warranty then your only choices are the GM Stage 1 or 2
Old Jun 19, 2008 | 02:12 PM
rnjmur's Avatar
I would go GM stage 2 and put one of Nates pulley's on there (like a 2.95" pulley). It would be a good idea to get some kind of cooling mods, the dual pass intercooler or a second/bigger heat exchanger, to help keep the temps down.
Of course if you want to stay 100% in warranty the most you can do is stage 2.
Old Jun 19, 2008 | 02:16 PM
RuSSo-29's Avatar
Stage 2, and a Dual Pass would be ok . As far as I'm concerned any way! lol
LamboW9's Avatar
yea...i keep recommending the zzp stage 3 or 4 because its cheaper and includes the tune...then the only thing outside paying for the stage kit that he would pay for is to ship the pcm to zzp to get reflashed and to get the pulley pressed off the stock supercharger
Old Jun 19, 2008 | 02:24 PM
OniMirage's Avatar
you could put your own stage 3 together if you want. The only real additions you need are a 2.9" pulley and a dual pass end plate. The rest of stage 3 is the addition of a new ecu which enables the ability to turn on a race mode and run a 50shot at the loss of your a/c
you can do whatever your want to the car even under warrenty. unless they can prove your mods caused an issue your in the clear. that doesn't mean they can't refuse service cus they can but you can try somewhere else.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
