GM Stage 3 PCM Problem
Old Feb 28, 2008 | 06:03 PM
eastcoastz's Avatar
I thought with the GM Stage 3 PCM you did not have to do a case relearn, but I keep throwing P0315! Anyone have this problem?
Old Feb 28, 2008 | 06:14 PM
Degashoot's Avatar
I was wondering that too.
From my initial research I learned that in general, when installing a new/different PCM, a case relearn is required.
But in the instructions of the Stage III kit that I found on CED they state that going from Stage II to Stage III and back again, is just a matter of swapping PCM's.
Old Feb 28, 2008 | 06:30 PM
ecotecon18s's Avatar
you do have to do the CASE learn once, then after that you can swap back and forth...my buddy works at the dealer and has both Stage 2 and 3...
Old Feb 28, 2008 | 08:52 PM
eastcoastz's Avatar
Thanks guys! Hey I wont be able to do a case relearn for a few days, will I cause any kind of damage?
Old Feb 29, 2008 | 02:01 AM
BlueSSupercharged's Avatar
cant do the crank shaft relearn on the stage 3 pcm i tried several times.
Old Feb 29, 2008 | 05:27 PM
eastcoastz's Avatar
Well I just did one on mine with my friends TEC2. Worked like a charm.
Old Feb 29, 2008 | 05:38 PM
Area47's Avatar
Rent me! per hour
you can case relearn the stage 3 ecm.
Old Feb 29, 2008 | 10:46 PM
mush be a problem with something on mine then it wouldnt let me learn it.
Old Feb 29, 2008 | 11:15 PM
eastcoastz's Avatar
Thats strange. Maybe somethings up with your crank sensor itself?
Old Apr 12, 2008 | 05:54 PM
rockkrawler628's Avatar
I just installed stage 3, but i can't start my motor because i broke the steam pipe bolt... so i had to call the dealership and they can't order one until monday... and they half to order the whole thing 80 bucks and all i need is the bolt not the whole pipe... but I checked my codes and it came up P0315... will a case relearn take that away.. im not sure what it means so im gonna search it
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
