GM Stage 3 Pulley on GM Stage 2 Calibration
I tried searching, but the search sucks on this forum sucks and brings up every possible stage kit out there for results. Anways, I am sure that this has been done before, but are there any ill effects of swapping the GM stage 2 pulley with a GM stage 3 pulley? I am sure that the injectors can handle it no problem, but will the slightly smaller pulley generate much more extra heat? Is anyone here strictly stage 2 without cooling mods and has went to a stage 3 pulley? If so, I am curious if anyone has logged a big difference in IATs or was able to see timing pulled. Basically I am wondering if using the stage 3 pulley is going to cause a decrease in performance compared to the stage 2 without first going to some sort of cooling mods
I ran it for a couple years on my SS/SC . Even thou it isn't much of a drop it was noticeable . Boost would come on quicker and I saw 1 PSI increase . The temps in NY are pretty cool compared to most places so I never noticed any performance loss from high IAT's . Even in the hottest weather we rarely see 90's F so if you live somewhere where it gets 90 -100 degrees it might be a different story .
BTW .... GM stated in their stage 3 FAQ that the stage 3 pulley was safe to run on the stage 2 calibration .
Where did you find the FAQs at, I'm interested in reading it. I found one FAQ article, don't know if it was offically published buy GM, and it said that the stage 3 pulley generates too much heat and requires cooling mods on the stage 2 calibration
Yeah, it is perfectly fine. GM does state in the Stage 3 instructions that the 76mm pully is fine to run with the stage 2 tune. IAT2 will be slightly higher without any cooling mods, but it shouldn't be bad except on hard runs in the hot summer months.
