GM STAGE KITs FAQs - Read Me First!
Old 12-15-2011, 09:01 AM
  #851
elig0nzal3z's Avatar
Originally Posted by ChriSS/SC
You guys are talking about 27-32 mpg? Wtf is wrong with mine? Haha I'm getting 21 stock. Wtf is going on here....
agreed wtf is wrong with my 05 ss/sc i get about 19 to 20 mpg babying it
Old 12-24-2011, 08:04 PM
  #852
thebucky84's Avatar
you have a wideband and HPT? If so you may have to make some adjustments to the tune or even observe your wideband to see where the issue is. Or better yet if you bought it through GM, take it to the dealership.
Old 03-22-2012, 04:24 PM
  #853
mark.lupatsky's Avatar
GM Parts Direct: Your direct source for Genuine GM Parts
i found this website that sells stage 2 kits for cheap its the cheapest i found on the net so if anyone is looking to upgrade i would suggest this
Old 03-23-2012, 01:19 PM
  #854
Dantos's Avatar
i got a stock pully in my ss whats the smallest size pully i can put in with out it slipping or changin the belt or injectors i think 3" but im not sure
Old 03-23-2012, 01:22 PM
  #855
sujomatt's Avatar
Recommend an adjustable tensioner!
Old 05-16-2012, 04:23 AM
  #856
TimJim's Avatar
how much would the reflash cost from the dealership? if its not like $1000 extra then i may do this soon
Old 05-16-2012, 09:03 AM
  #857
No more than 100 id say
Old 05-16-2012, 07:13 PM
  #858
WopOnTour's Avatar
Providing you have already purchased a GMPP stage kit and installed all the parts I would agree. Basically an hour minimum to reflash the PCM. (even though it will only take a fraction of that) BUT DO NOT LOSE THE SERIAL NUMBER SHEET THAT COMES WITH THE STAGE KITS! They will need that number at the dealership in order for them to call GM Techline and request the rep to "assign" your car as having the factory stage kit installed.
The good news about that is if you ever get reflashed by the dealer (eg. your PCM "fries" and it gets replaced) it will always be the latest cals for whichever stage kit you have. (your VIN is automagically associated as being a "stage" car)
The bad news is that if you use another aftermarket programmer such as HP Tuners to alter your tune (even just the rev limiter) these alterations will be "reset" back to factory stage tune level should you eve get a reflash at the dealer. (but hopefully you'd have a back up of you modified tune anyways so , not such a big deal)
HTH
WopOnTour
Old 01-20-2013, 02:47 PM
  #859
Cooperda3rd's Avatar
Where I live getting any gas over 91 octane is pretty tough. I want to stage 2 my car I know you are supposed to run 93 with this kit. Will running 91 create issues...Keep in mind the 91 here in Canada is absolute garbage. How much worse will the gas mileage be as well? I get about 500km a tank right now.
Thanks i believe this is my first post on here but I'm a long time reader.
Old 01-20-2013, 03:27 PM
  #860
07touringcoupe's Avatar
You should be ok with 91 oct. the tune is relatively safe and rich. I'm sure you won't run into any problems.
Old 01-20-2013, 03:49 PM
  #861
CrateEngineDepot's Avatar
agreed
Old 01-20-2013, 04:32 PM
  #862
Powell Race Parts's Avatar
there is nothing wrong with Canadian gasoline. All winter gasoline north of Georgia or so, has a different RVP for cold starting...Shell gas which is available near where you live, is a tier one gasoline supply and their 91 octane has no ethanol. Another Tier one supplier is Petrocanada , their 94 is available near where you live as well, it has ethanol , but that helps make the octane.
Stage 2 s/c works well on 91... but will be noticeably better for mileage in summer when gas RVP changes and the weather is better. Crate engine depot have good prices on the complete kit, and any GM dealer anywhere can flash the install from the information and codes provided in the OEM kit.
Old 01-23-2013, 05:48 PM
  #863
Thanks guys. Going to get that done then. I do use 94 as much as I can but in the town I live we only have ultramar and esso. Looking forward to the extra hp already
Old 01-07-2014, 03:05 PM
  #864
dustyd18's Avatar
I got an 06 with a 77.9 pulley pushing 15psi of boost on stock injectors with a redline of 6500 so its def dont have a stage kit. Is this safe for the engine?
Old 01-08-2014, 07:15 AM
  #865
Administrator
Administrator
Staged07SS's Avatar
S2 pulley on stock injectors is retarded. Please install 42's or larger asap!!!
Old 12-01-2014, 11:35 PM
  #866
beast124's Avatar
Very stupid thing to do! The idc's are through the roof and beyond static im sure..pick up some 42's or even 60's for more growth
Old 04-10-2016, 11:33 AM
  #867
Orange06SC's Avatar
I have a question regarding the stage 1-2 kit. I already have the stage 1 installed, and want to add the stage 2 pulley, would I be able to do this?
Old 04-11-2016, 07:04 AM
  #868
Administrator
Administrator
Staged07SS's Avatar
Yes.
Old 04-11-2016, 07:30 PM
  #869
Orange06SC's Avatar
Thanks Staged07
Old 04-12-2016, 07:10 AM
  #870
Administrator
Administrator
Staged07SS's Avatar
Thanks Staged07
Welcome!
The route you are going is how I started out back in 07'.
Old 06-24-2016, 11:59 AM
  #871
ricklovin93's Avatar
Is a trip to the dealer needed for a reflash for stage 3? Or is the PCM included in the kit already loaded with the tune.
Old 06-24-2016, 12:29 PM
  #872
Administrator
Administrator
Staged07SS's Avatar
The dealer does not have that tune.
It comes preinstalled on the GMR Stage 3 PCM.
Old 09-17-2016, 07:46 AM
  #873
07CSSSC's Avatar
Can you tell what injectors you have by the colour? What is the stock injector colour? stage two colour?
Old 09-18-2016, 07:43 PM
  #874
Got Bewst?
Bluelightning's Avatar
Stock injector color is green. Stage 2 I believe is just black.
07CSSSC (09-18-2016)
Old 09-19-2016, 08:33 AM
  #875
Administrator
Administrator
Staged07SS's Avatar
Stock 34lb/hr injectors have a green connector and metal body.
GMPP 42lb/hr injectors have a black connector and metal body.
Lucas 42lb/hr injectors are all black.
60lb/hr injectors are pencil style (skinny/longer), and are all black.
Quick Reply: GM STAGE KITs FAQs - Read Me First!
