gm tune question
Old Aug 11, 2008 | 05:24 PM
usdm08's Avatar
gm tune question
hey guys wuz up? will the 60lb injectors work fine wit the gm tune? or will i need to get the car tuned again? becuz i have 42's wit the gm tune.
Old Aug 11, 2008 | 05:25 PM
plaxton's Avatar
i would highly suggest getting a retune for the 60lb injectors.
Old Aug 11, 2008 | 05:29 PM
CBodnar's Avatar
read below. i have no clue actually. my bad
Old Aug 11, 2008 | 05:33 PM
usdm08's Avatar
its that i have a 2.7 pulley on the 42's n idk if i should get a 2.8 pulley or get 60lb injectors, its that theres nowhere to get a custom tune in miami.
Old Aug 11, 2008 | 05:52 PM
rnjmur's Avatar
If you put 60# in there you need a retune. If you leave the stage 2 tune you will be running WAY rich.
Old Aug 11, 2008 | 11:18 PM
theneelster's Avatar
He could just get a maf translator and lean it out. That's the cheapest way he's going to be able to tune but it's not accurate at all.
Old Aug 12, 2008 | 03:01 PM
Maxim_X's Avatar
No the car will barely run with 60's lol. You can't just swap them. I bet the car would go into limp mode. It just won't work. Their is no highly suggesting it, if you run 60's you need a tune.
No buddy really uses a maf-t since hp tuners became mainstream.
Old Aug 12, 2008 | 03:03 PM
WickedSS2005's Avatar
No, CANNOT use 60's w/o a custom tune. If you want more power, use a 2.85 pulley with the GM tune on the 42# injectors
Old Aug 12, 2008 | 03:04 PM
Psykostevo's Avatar
translating MAF without knowing flow values etc is super retarded.
You seriously need a tune to run 60's.
My best suggestion is run a 2.8" or larger pulley with the gm injectors and STILL get a custom tune. I saw a GM stage II with nate's 2.8" pulley running 13.5 AFR at WOT. That's killer right there.
Old Aug 12, 2008 | 03:05 PM
ShortStack's Avatar
I understand that it wont work, but why?? Does it dump THAT much more fuel into our system? I want flames shootin out the back! Haha.
Old Aug 12, 2008 | 03:09 PM
The car thinks it's running X ammount of fuel on 42's but in reality it's running Y ammount due to the 60's. So it's going to be running VERY VERY rich
Old Aug 12, 2008 | 03:11 PM
Psykostevo's Avatar
The reason is not in the injectors themselves, but in the voltage that the injectors run at.
You put 60# on a 42# tune and you're shooting 50% more fuel in there than normal. Your car CAN learn to readjust for your stupid ass at IDLE, but not under WOT. The reason is that the car learns LONG TERM fuel trims and is able to compensate for incorrect fueling while under a constant condition, but under WOT you car actually stops learning LTFT and will just pulse the programmed amount. You cannot hold the car under WOT and teach it to learn, because that feature is disabled for good reason. Afterall you don't want you car leaning itself out to 14.7 AFR under WOT either.
And to those who think I just said that your car will learn and tune itself......you're idiots. Some dude on the redlineforums tried telling everyone there that we don't need custom tuning and tried to prove it by using different injectors and a wideband. Even if your car learns to adjust for itself, it takes the computer a long time to reference those changes and calculate the proper amount. That's why better tuned cars run better, the computer is not having to compensate and delaying the actual results. Plus, under WOT there are no computer compensated changes so you're SOL. You could have a car that drives fine around town, then you don't know how bad it runs under WOT.
Word to the wise: If you don't understand how a part works.......don't put the F-ing thing on your car.
To the OP> If you are running a 2.7" on a stock GM tune, I would go to a engine shop and have a LEAK DOWN test performed to make sure you haven't already cracked the sides of your pistons. It may feel fine to you, but your pistons could already be near toast.
hatrickstu's Avatar
holy wow, your motor hates you
Old Aug 12, 2008 | 03:18 PM
Psykostevo's Avatar
I heard that the local tuners in Miami beat you up and hold you ransom and threaten to kill your family if you don't pay up.
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Extremespeed
Sep 29, 2015 04:34 AM
