Gm Warrany
Old Oct 3, 2007 | 10:28 AM
dylan1221's Avatar
Gm Warrany
im planning on calling gm today. and seeing if i can get a new clutch . . its basically gonna go anyday noww.. i bought the car used with 14,000 miles now it has 36,000 im not sure of the warranty i got with it at all.. what do u think they wil do
Old Oct 3, 2007 | 10:30 AM
SilvrLT's Avatar
if yor car ha the 5yr 100,000mi warrenty they should replace it
Old Oct 3, 2007 | 10:31 AM
killah_thug08's Avatar
i got a 07 with extended warranty so does that mean my clutch is under warranty till 160000 km
Old Oct 3, 2007 | 10:32 AM
Element2.4's Avatar
Most likely they wont replace it. A clutch is a Wear item. Take it to the dealer and see though.
Old Oct 3, 2007 | 10:37 AM
R&C_rallySS's Avatar
Wear items are not covered. You can try but if they say no don't waste your time fighting them.
so wats under extended warranty
Old Oct 3, 2007 | 11:29 AM
Onyxd04Redline's Avatar
Clutch's are wearable item's and are NOT covered under warranty
Old Oct 3, 2007 | 11:31 AM
ridemlow03's Avatar
unless it wore down because of some type of hydraulic problems then they wont replace it. i have 12000 miles on my car and my clutch is gone, if im in gear and hit the gas a little it just revs up. its my fault, i had way to much fun with it.
alleycat58's Avatar
Yeah, they're going to tell you to go pound salt. Clutch would only be covered within the first 7,500 - 10k miles IF there was a manufacturer's defect. What's covered under your extended warranty depends, but a lot of times it's limited to drivetrain. Basically engine/transmission minus the clutch.
Old Oct 3, 2007 | 11:34 AM
Fresh's Avatar
if you have only the 36000 you're screwed...
i had the facotry 36000 but with the 60000 extended warranty. my clutch went out at around 37000miles and they replaced the entire clutch system except for the pressure plate which i had to pay out of pocket about $120. they said it was defective...
Crazybouy35
Canadian Mid West
Nov 10, 2011 02:09 PM
jacobpaschall
Jan 25, 2011 11:12 PM
dayhoff35
Sep 7, 2010 02:46 PM
dayhoff35
Jun 27, 2010 10:03 PM
rockstarbass1
Jun 11, 2010 03:38 PM
