going to attempt
Old Jan 16, 2011 | 09:10 PM
DEZZIE41's Avatar
going to attempt
going to attempt to install my heat exchanger in my drive way tomoro any one got any advice on the install or how easest way to get the job done
Old Jan 16, 2011 | 09:12 PM
redcobalt07's Avatar
remove the bumper and all that other stuff in the way so you can access it easier
Old Jan 16, 2011 | 09:13 PM
SilverSS_TNR's Avatar
its easy, for 1- you dont have to remove the bumper, so dont, 2- a dremel works wonders on taking off the stock hoses, they are a pain in the ass, 3- lift the car up as much as you car to give yourself plenty of room to work under, 4- when your done make sure you add plenty of coolant cuz you should be adding 1-2L more at least.
Old Jan 16, 2011 | 09:14 PM
DEZZIE41's Avatar
ill be doing it in my drive way cause im to lazy to take it to my shop and do it how long it take to do give or take
ehhh i would have to disagree, i remove the bumper on mine, i couldnt get the bumper back on correctly, it took forever, and i also did it one my buddys car, we didnt take off teh bumper and it took a fraction of the time
Old Jan 16, 2011 | 09:15 PM
ssblackstealth's Avatar
corn gas ftw....
its wayy more difficult with the bumper on! and not hard at all to take off/put back on.....
1-2 hours depending how good you are with removing stuff.
Old Jan 16, 2011 | 09:16 PM
DEZZIE41's Avatar
im a mechanic by trade so
i think is just the lines that are going to **** me up
then you should be good, just dont remove the bumper whatever you do lol
the lines are bad at all, if you have the diagram youll be fine, it makes alot more sense when your under the car then just looking at a sheet of paper
Old Jan 16, 2011 | 09:18 PM
DEZZIE41's Avatar
where does the he mount to i take it ill have to do some improvising?
Old Jan 16, 2011 | 09:20 PM
check the how to, i cant remember exactly where, but i know its not hard at all.
Old Jan 16, 2011 | 09:21 PM
DEZZIE41's Avatar
the corba he how to?
Old Jan 16, 2011 | 09:24 PM
07BoostedG5's Avatar
yea that was legit ^
Old Jan 16, 2011 | 09:26 PM
DEZZIE41's Avatar
ill c if i can find it
does it matter is mine is zzp stage 3 though
1LowLS's Avatar
Ii have the OTTP gen2 dual pass which is massive.I did not remove the bumper for installation.Either use Jack stands or blocks of wood to hold the heat exchanger up,mark your holes and drill.I used a step bit which works wonders on the crash bar.put the bolts in and make sure to use lock washers.It took me about 30 minutes.Not hard at all.
Old Jan 16, 2011 | 09:29 PM
DEZZIE41's Avatar
my he is a dual pass so does it matter where i put the line coming off the ic pump
Old Jan 16, 2011 | 09:33 PM
1LowLS's Avatar
I'm not too sure on the dual pass I can't remember the routing on it.I know the how to shows exactly how to route the lines.I'm still on a factory endplate so mines different.
Old Jan 16, 2011 | 09:35 PM
DEZZIE41's Avatar
oo
oo
Old Jan 16, 2011 | 09:36 PM
05Slowline's Avatar
bro comon use the diagram i put in your other thread it's not complicated at all and you saying your a mechanic should make it a no brainer. idk if the holes they used for s3 in the cobalt crash bar are existing or not, i drilled my own on the rl and found some nuts and bolts that worked.
Old Jan 16, 2011 | 09:38 PM
DEZZIE41's Avatar
ya im mechinc but not for cars lol i work on the big rigs so things are a lil diff lol
Old Jan 16, 2011 | 09:41 PM
05Slowline's Avatar
it's just swapping 2 hoses lol you take the stock h/e OUT hose off and put it to the zzp IN then go from the ZZP out to the ic pump IN which is pointing sideways looking under the car
god forbid you were doing dual pass with this
Old Jan 16, 2011 | 09:42 PM
DEZZIE41's Avatar
ya i knwo i would be totaly fucked then hahah
im use to turbos not sc
Old Jan 16, 2011 | 09:46 PM
05Slowline's Avatar
so just turbo instead
i'll prob never buy another car with an air to water ic lmao
Old Jan 16, 2011 | 10:12 PM
DEZZIE41's Avatar
how long of bolts do i need/
Old Jan 16, 2011 | 10:17 PM
Bluelightning's Avatar
Got Bewst?
I just removed my grille, jacked the car way up and had it bolted in in about an hour. It's easy.
