Good Buy?
Old May 5, 2007 | 11:51 AM
chevysalesman614's Avatar
Good Buy?
http://www.lethalperformance.com/pag...exchanger.html
Will this one cool me down better than a stock H/E from a cobra?
Old May 5, 2007 | 12:08 PM
blueta's Avatar
I don't know how true it is but I've heard the stock cobra system is one of the best. Someone told me that one of the mags did a test and the stocker barely changed temps throughout the whole dyno beating when being compared to the others. Not sure if they're talking the system as a whole or just the h/e though.
Old May 5, 2007 | 12:14 PM
joeworkstoohard's Avatar
for the balt, i think the stock cobra one is the best bet. it's already way over sized for the car, and the price is hard to beat.
Old May 5, 2007 | 12:15 PM
yellowcobaltss05's Avatar
just get the cobra HE and the bwoody brackets all for $150 and your intake temps will be down 15-20 degrees at WOT
Old May 5, 2007 | 12:21 PM
spaz's Avatar
Dude just get the he off e bay It is the same one as the group buy way cheaper and way easier to install cause the fittings come out the side. I have one in my car works great
check my gallery and pm me if any questions.
Ciao,C
Old May 5, 2007 | 03:31 PM
ralliartist's Avatar
what are you guys talking about? that fluidyne heat exchange is a triple pass design. the only one on the market as far as I know. There is a guy in a redline over on the redline forums that runs it and he says that after many hard wot high boost passes, it still feels like a bucket of ice. That is like the best heat exchanger you could get. It's the one I'm saving up for.
Old May 5, 2007 | 04:46 PM
BakNBlack's Avatar
hey guys you talked about brackets, is there like a bracket kit i can get for me to put an h/e in i already have, stock cobra model???
Old May 6, 2007 | 04:18 AM
www.bwoodyperformance.com has the brackets for the cobra HE
Old May 6, 2007 | 04:46 AM
RA071623's Avatar
ooh that looks sweet thanks for the idea........
Old May 6, 2007 | 05:17 AM
Cobalt_Supercharged's Avatar
Most of the aftermarket HE's for the Cobra are too thick to fit between the bumper and the AC condensor.
Also the Cobra HE is only about 1" thick which is the optimal thicknes for an HE. Any thicker doesn't bennefit because the air gets too hot after passing through the first inch that it doesn't really remove anymore heat from the coolant. It just holds significantly more coolant so it takes longer to heat soak.
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
