Great Cheap "mod"
Originally Posted by StreetDreamz
I will correct you because the radiator and heat exchanger both use different overflow tanks and lines all together. Lol. I think they just painted the tank a chrome look to match the intake.
Correct,
the engine coolant and intercooler coolant two entirely separate systems,,,
nothing from the two intermingles.
Originally Posted by ReMz
it would look sexier in his old sig......
not a bad idea. at all.. wow... :P
Originally Posted by NightriderCobaltSS
Where could you get something like that at. Like Hardware Store or and Auto Parts Store or both ?
Originally Posted by SS33
Correct,
Correct,
Originally Posted by hatrickstu
where is the intercooler tank then
You can buy the heat wrap at most performance shops. Probably not at pepboys or checker, but at a real shop.
As for the "track days" I drag race every other week, and when your cars thermometer reads 121* at 10:30p.m. you need all the cooling power in the world to get a good run. There is no such thing as cooling down between runs in that kind fo heat.
Originally Posted by Psykostevo
There is no intercooler tank. The intercooler resivoir is that little tiny thing mounted near the supercharger that has a overspill tube, and a little ____Fill line. That's it.
I feel bad for telling you your sig was too big yesterday, lol, I'm an arsehole
You could have left some of it on there, sorry
you will not see ANY difference in performance from rapping your air tube... its constant quick flowing air... its not gonna make any difference if your air is 1* cooler going into your engine..... dont waste your money on this
It seems like a good idea could this be used anywhere on the car to try an lower ambiet heat under the hood.
Like Heat wrapping the Exhaust Manifold.
I got my thermo heat reflective wrap/tape
As far as the intercooler, and engine coolant, I use a liberal dose of Redline Water Wetter to help bring down the temperatures. I have used Water Wetter in my race cars over the years, and turbo vehicles I have had with good results. On my race car I also have the heat reflective tape covering the fuel line all the way from the fuel cell in the trunk to where the fuel line goes into the carburetor.
I also painted my extrude honed exhaust manifold with ceramic header paint before I installed it. Heat is the enemy of high performance not only in race cars, but especially boosted turbo and S/C cars.
It is also a pretty good idea to cover the gap in front of your intercooler with bug/rock screen of some sort. Within the first 80 miles I had on my car I noticed about 100 bent over fins on the I/C from highway rocks. This does not help the intercooler do its job, nor does it help to have the I/C plugged with grasshopper or other bugs. If you haven't done this, take a good look at your I/C and you'll see what I mean.
Doc
Originally Posted by mrdoc442
from Summit Racing. They have many types to choose from, including their own brand at a pretty good price, but I like the Heat Shroud w/Velcro (DEI-010405) - you don't have to take anything apart, so it is easy to put it over the fuel line and just snap it together; and I like the adhesive backed Cool Tape (DEI-010408) for areas that are accessible, that you might want to wrap tight. There are a lot of other sizes, brands, available to suit your needs. Most mail order speed equipment or retail stores that have Hi/Po stuff for sale should have it.
Doc
Doc
