Gtech RR Setup
Old Oct 12, 2007 | 10:16 PM
smurfy79's Avatar
Gtech RR Setup
Just wondering if anyone else on here has the Gtech RR on the 2.0L Supercharged? If so did you have any trouble calibrating the RPM's? I can't seem to get them set correctly ...getting frustrating and there is absolutely no help on Gtech's website or the manual...
Oh, and by the way, jbodyperformance.com is having a blowout on the Gtech RR...$199!
Old Oct 12, 2007 | 10:18 PM
XM15's Avatar
What is the Gtech RR?
Old Oct 12, 2007 | 10:27 PM
smurfy79's Avatar
Check out http://www.gtechpro.com/rr.html
Old Oct 13, 2007 | 03:24 AM
splitimage's Avatar
waste of money.
Old Oct 13, 2007 | 06:52 AM
OzzyruleZ's Avatar
I borrowed my friends Gtech Pro SS and trust me, there is no way to get it to work right on our cars. I finally found a setting that semi works. when you are at idle or cruising a constant speed the rpm's will "jump" around a lot but under WOT it will read correctly for the most part.
Old Oct 14, 2007 | 12:36 PM
smurfy79's Avatar
Well I think that I have it figured out, I managed to get it to the point where it reads the RPM's fine when I'm moving, if I'm stoped however they sometimes jump all over the place. I tried a 1/4mile run but I screwed up on the launch and missed the first shift to second but here was some of the results... 0-60mph=6.258sec, 1/4mile=14.625sec, max hp=189.24 (net hp). Seems like these results could be pretty close, I'll find out when I get to the track I suppose.
Here's a chart that I downloaded from the Gtech, I'm gonna make a few more runs today and upload 'em tonight...anyone know if this looks close to what I should be seeing? Minus the hp and torque of corse 'cause this measures "net hp".
Old Oct 14, 2007 | 03:47 PM
euthanasia's Avatar
Yeah mine does the same with the jumping RPM at idle or somtimes it does it when just driving at a steady rpm.
Old Oct 14, 2007 | 04:40 PM
firemanfrank's Avatar
It's too bad that the G-tech doesn't work on our cars.
Because according to a test done by Car and Driver of performance meters, if a G-tech is used on a car that is on a level road ... it is EXTREMELY accurate.
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
cw383
Sep 30, 2015 12:41 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
