Guess my HP
I am doing tuning myself with help from Riceeater his redline put down 420whp until he snapped his crank reving at 8-9k forgot neutral balance shafts
but rice eator myself scott at cobalt performance parts and a few of my buddies that tune dsms i should have a pretty mean tune
If spooner or someone who has tuned an lsj before is there tuning it with you...291whp
Otherwise 280.5.
These assumptions are for a dynojet 2wd dyno on 94 or less octane gas w/o alky/meth/water/n2o injection
Otherwise 280.5.
they have tuned lsj's before and rice eater is on the redline forums
some of these numbers are pretty interesting
i did 267 whp with a 2.8 42.5 injectors and a maf -t
add smaller pulley hp tuners header exhaust CAI bigger injectors non slipping clutch and higher compression.....
if i dont get over 300 ill flat cry
I don't think you will be over 300. As you start dropping pulleys you gain much more torque than hp. Also, you have no head work like Riceeater had. RiceEater even admitted he wasn't too sure how reliable is 425whp was. You may be close, but I think you will have a hard time tuning with the 10:1 pistons and a 2.5. I know Spooner had a hard time tuning with RiceEater at first.
