Guys with Aeroforce ...can u check a parameter for me so I can compare
You dont even need to drive your car . Jus turn the key on , set 1 reading at " throttle pct " and tell what # it is when the gas pedal is pressed to the floor . Im assuming this reading is the percentage of throttle the accelerator is telling the throttle body to open (?) . ~Or is this value mean something . This is the first drive-by-wire Ive had , and all the cable/TPS cars Ive had , have read 100% when the gas pedal is fully depressed . The throttle pct reading in my SS only reads 87 at WOT . Just trying to see if thats normal or not .
Thanks
Thanks
ok , its probably just normal then . Thats all I wanted to know . I put the GM accessory pedals in , before I got the aeroforce , so I wondered if maybe the all new accessory pedal has a problem . Looks like it doesnt .
TurboTechRacing
Oct 27, 2015 07:58 AM
twilson380
Sep 14, 2015 10:52 AM
