HAHN 3" catback
HAHN 3" catback
So here is that plan, let me know what you think. I currently have a zzp header and DP with stock catback and a magnaflow muffle. (too raspy/tinny). I'm plannign on buying a hahn 3" catback with 2.5" bolt-up end. The pan is to run this first for a while and possible up grade to a 3"DP which hahn's catback allows for because i can just swap the 2.5" end for a 3". What do you guys think?
How would you swap the 2.5" end for a 3" ? Cut/weld? Also, make sure your ZZP downpipe is, infact, 2.5". I thought mine was 2.5" but turns out it's a 3" with a 2.5" exit for my Magnaflow exhaust.
Hahn has a feature where all you have to do is swap a little portion at the end to a larger exit. the exit on my d/p is bolted to my stock catback so it has to be 2.5" what do you think sound will be like ?
nope I have a high flow cat in my zzp downpipe. Do you think it would sounds good?
Any opnions?
Any opnions?
Last edited by krazycobalt; Apr 23, 2009 at 12:33 AM. Reason: Automerged Doublepost
I would just wait till you get a 3" downpipe if you are going that route. It's best to keep it all one size imo so you aren't "bottlenecking" anything. Plus its a pain to keep switching different sized flanges. Other people may have other opinions though. The CTI 3" catback would be nice as well.
