hahn turbo kit
Old Jul 27, 2009 | 03:50 AM
BIGGSS_SuperCharged's Avatar
hahn turbo kit
im a newb but i want to put the Hahn turbo kit on my 07 ss/sc but idk if it is a special turbo kit or what so if you guys could help me it would be awsome thanks.
Old Jul 27, 2009 | 04:01 AM
Spectral's Avatar
umm you can get help but you might want to post some questions or more info...kinda vague right now what you need help with exactly.
Old Jul 27, 2009 | 04:12 AM
Wolf117's Avatar
not gonna be cheap lol
Old Jul 27, 2009 | 04:24 AM
Angel's Avatar
Not cheap but worth it. As the good ol saying goes, "You get what you pay for!". This is truly an amazing turbo conversion from Hahn.
Old Jul 27, 2009 | 04:43 AM
Spectral's Avatar
Well what are your power goals? Why do you want this kit versus other ways to gain power? Is it your daily driver? etc.
Old Jul 27, 2009 | 05:21 AM
Wolf117's Avatar
i totally agree. was just saying its not cheap haha i would love to do this
Old Jul 27, 2009 | 02:29 PM
Jmoney's Avatar
Talking
it depends on your goals and what u want weither it be turbo or supercharged. if supercharged to be in the low 300s get a tvs. if u want 400 or higher get the twincharge kit or the hahn kit. me personaly I like the twincharge kit. you get best of both world and it is cheaper hahn kit and makes the same kind of power with a price of 3200 compare to almost 5 grand for the hahn kit. best of all no lag. "its your boost us it when u need it"
Old Jul 27, 2009 | 04:15 PM
Spectral's Avatar
Twincharge is still pretty iffy for me. I don't see cars lasting as long. If you just want a really fast DD the best option is the TVS....its cheaper, easier and with the right supporting mods you can get well over 300whp.
Old Jul 27, 2009 | 04:50 PM
Angel's Avatar
Lets clarify something before this thread turns to **** like most others have. Sooooo many people out there are going TVS and several recently are going twincharged primarily to be "DIFFERENT". Now the funny thing is that there are probabaly just as many TVS guys out there as there are Hahn guys and many less twincharged for obvious reasons. Lets have a look at pros vs cons of all of these systems.
1) Turbo Charging Pros(Based on Hahn) - Naturally aspirated, much more power to be had, easier power gains, more efficient than any other, IAT's are about 40% than that of Supercharging, very quick spooling with not much lag whatsoever
Turbochargine Cons - Lag, but as I explained with the Hahn system it spools up so quickly you have a hard time even noticing any
2) Supercharging Pros(Based on TVS or stock w/stage II) - Decent power gains
Supercharging Cons - Tougher to obtain alot of power than that of Turbocharging, Belt driven, HEAT!!!!!!! Lots of Heat!!!! Worst enemy, Our cars love to run cooler as any other. More potential problems due to heat.
3) Twinchargine(Based on ZZP's setup) Pros - No lag, better bottom end power to get rid of the lag, Lots of power to be had
Twincharging Cons - Just another something something to fuc* up, does require finer tuning, Not as reliable as either turbo/supercharging
Now with these pros/cons being pointed out lets go over a few obv things with the LSJ when moding. First off, ZZP specifically Zooomer preaches to everybody that certain things are not required for our cars and just plain useless as its something else that can go wrong. Well imo I believe the same can be said for the twincharging setup for 1 specific reason - We have enough of a hell of a time keeping the wheels on the ground. I believe that with the Hahn turbo, there is soo much power to be had way more than enough and you still benefit from very low IAT's and efficiency. I personally love having a very slight lag due to the fact of the traction issues. Feel free to state you own opinions but I know this is useful information to many people who dont understand some of these basic principles.
Old Jul 27, 2009 | 04:57 PM
BumbleBee's Avatar
well put^^
I will be going hahn ASAP, right after my warranty runs out lol.
Old Jul 27, 2009 | 05:24 PM
Zooomer's Avatar
Supporting Vendor
In one sentence you say heat is the enemy, in the other you say twin charging isn't needed. Twin charging allows a larger turbo and twin intercooling which lowers temps.
-Next, saying IATs are 40% of superchargers doesn't even make sense. Not because it's wrong, but because the math doesn't work like that. You can't have a temperature be 40% of another like you're describing. For all temperature math (and you are doing math by citing a percentage) you have to convert to Kelvin. Clearly the person who says this has no idea how that works.
-Twin charging in many ways requires less tuning than with a turbo only. The car behaves like stock so you don't need to tune around the bahavior of a turbo that has lag or varying boost levels at different rpms/loads/etc. The myth of the tuning issue is from people who do it on their own and do not understand component selection or the basic setup.
-YOu missed the reliability pro of supercharging. Nothing comes close to the reliability of an Eaton.
Old Jul 27, 2009 | 05:34 PM
Angel's Avatar
Originally Posted by Zooomer
In one sentence you say heat is the enemy, in the other you say twin charging isn't needed. Twin charging allows a larger turbo which will have lower temps.
-Next, saying IATs are 40% of superchargers doesn't even make sense. Not because it's wrong, but because the math doesn't work like that. You can't have a temperature be 40% of another like you're describing. For all temperature math (and you are doing math by citing a percentage) you have to convert to Kelvin. Clearly the person who says this has no idea how math works.
Zooomer, your an idiot plain and simple. I said 40% as an approximation. Do you know why???? Mabye because when I was stock supercharged with the stage 2 kit I was reaching temps of over 250F and now that I am turbo'd I havent even seen 100F. Now you try to get right down to the science whereas I was just stating an obvious point that IS PROVEN. No need to try to act like god because your not. Your just a **** disturber. Just leave one thread alone for god sake so people wont mind reading it. Also, by the way in case you havent figured this out - Not many people like you nor like reading your bullshit! Get the point? I sure hope so.
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
maliki778
Oct 1, 2015 07:39 PM
