Has anyone done this??
Old Jul 7, 2006 | 03:25 PM
SchwarzCamaroRS's Avatar
Find a dubmass who has totalled his NA SS, take his crank/rods out, swap the pistons from your SC SS, but use the 2.4 crank and rods.... so esentially, you will have a 2.4l with the same compression as the LSJ... No REplacement for DISplacement... Bumping the displacement 20% or so should up the power just a tad...
Old Jul 7, 2006 | 03:33 PM
patathSS's Avatar
I doubt anyone has done this. Would you have to adjust your crank position sensor? Or your timing chain that drives your camshafts? I guess start looking for a demolished NA SS!
Old Jul 7, 2006 | 03:34 PM
Sicklyscott's Avatar
Wouldn't the bigger crank reduce redline? Thats one aspect that makes this engine great is the 7k+ that you can squeeze out of it. I know when you have a bigger stroke, you have to lower the redline.
Old Jul 7, 2006 | 04:16 PM
maybe a few hundred rpm, but the torque gains would be sufficient enough to make it not need the extra 500rpm. What does the 2.4 redline at? and i know this is apples and oranges, but if a nascar with a 354cid motor can redline at over 10,000rpm, i think our little guys can run 7. You would probably have to change everything off the 2.4 bottom end to the 2.0 stuff, the CPS and timing chain gear, but if LSJ's are anything like small block chevy's, the only difference between longer stroke cranks is the stroke, the crank postition will still be the same. The crank is still going to make 360 degrees per rpm regardless of stroke, so the crank position sensor should be fine.. Guys stroke their LS1-6 motors all the time... id move everything over just to be safe though...
Old Jul 7, 2006 | 04:20 PM
SS33's Avatar
Are the 2.4 rods forged?
I know for 2.2 build ups GM recommends using the 2.0 con rods w/ forged pistons
I'd just hate to see someone go to the trouble of putting in the new crank and having the rods now become a weak point.
Old Jul 7, 2006 | 04:25 PM
very true... hmmm the crank/rods would have to be just as good as the 2.0 ones for this to work... i dont see why they wouldnt be though, the 2.4 is still an SS and GM knows its going to be modded...
Old Jul 7, 2006 | 04:27 PM
SS33's Avatar
I know the crank is no problem. Hell even the 2.2 eco crank is stronger than any of us will likely ever need.
I just didn't know about the rods,,, anyone know on these?
If they are forged then hells yeah I wanna see someone try this, gonna be tough to find a junked 2.4 so early though I bet.
BTW, I love the camaro man, always had a thing for 3rd Gen droptops
Old Jul 7, 2006 | 04:34 PM
yeah, but could u imagine... lol, the NA power of the 2.4... with the SC... torque anyone??? no more of these 2.4-2.6 60-fts... thx man, i bought the cobalt cuz the camaro kept breaking... lol no warranty to fix it.. but its modded...
Old Jul 7, 2006 | 04:41 PM
SS33's Avatar
I had an 83 Z28 CFI when I was in High School, but someone decided to back over the rear end with a lifted blazer :-(
Old Jul 7, 2006 | 04:45 PM
SS33's Avatar
Back on topic though, the only other thing I'd be worried about would be valve clearance if we swapped to the 2.4 con rods.
It'd suck to fire it up only have a piston try to send your valves through the hood
As soon as the 2.4 came out I started thinking about frankenECO engines, like an LSJ with the VVT head from the 2.4,, yummy. I don't think the 2.4 head is as strong as the sand cast 2.0 heads though, anyone?
I'm sure it's only a matter of time though til we start seeing people attempting crazy stuff
OUCH!!! Mine decided to overheat on the way to arizona and i lost a valve, two days prior to that a pole jumped out and dented the crap out of my fender... the top is completely destroyed... its got a lot of work that needs to be done... lol My cobalt is for beating honda's and subaru's..... my camaro (when its fixed) is for running 12's.... lol I still love the camaro more than the cobalt, i dunno why... its just got this something... I think its called 8 cylinders of american muscle... lol. Still the cobalt gets CRAZY props... I dig the hell out of this car...
Old Jul 7, 2006 | 04:47 PM
SS33's Avatar
^^^ Yeah I def. miss the rumble of the V8
Old Jul 7, 2006 | 04:48 PM
torrin1234's Avatar
Yay for camaros! my dad has a 74? or 78? Z28 in beautiful condition... That I get
Old Jul 7, 2006 | 04:49 PM
SS33's Avatar
My dad had a 78 Z28 that we rebuilt way back in the day, it was the car I came home from the hospital in when I was born actually.
Def my fav generation of camaro
**Pushes topic back on topic**
Eco bitches, lol
Old Jul 7, 2006 | 04:50 PM
torrin1234's Avatar
mine too... I love the look.
Silver + Black factory Z28 Stripes
Old Jul 7, 2006 | 06:09 PM
mhump428's Avatar
I used to have a 85' monte carlo ss then me and my dad put a 350 froma 1980 pick up in it and got it bored out. man that engine would scream. loved every second of it though no matter how many times it broke down on me
