have a question
Old May 3, 2010 | 08:29 PM
erackSS's Avatar
have a question
so i have a 05 ss sc
and there is a rattle comeing from my exhaust
i believe it to be my resinator
i have alrdy replaced my flex pipe as that was leaking and makein a boat load of noice
my question is
if i just remove the resinator will i have any running issues?
any1 done this?
my car is mostly stock only a intake
thanks in advance....
Old May 3, 2010 | 08:30 PM
DEZZIE41's Avatar
my car does the same thing i think its just the metal cooling ive tyred everything and mine still does it im use to it now
Old May 4, 2010 | 07:19 AM
erackSS's Avatar
it does it as im driving
im not worried about the noise of it cooling when i park just the rattle on accel
Old May 4, 2010 | 07:43 AM
roser4888's Avatar
I cut out mu resenstor and welded a straight pipe in. Its a lot louder and have no issues with it
Old May 4, 2010 | 07:21 PM
erackSS's Avatar
awesome thats wat i like to hear lol
i will hopefully be doing this soon
thanks guys
Old May 4, 2010 | 07:35 PM
SlowCobaltisSlow's Avatar
Careful with this. Loud exhaust will occasionally **** off cops. With out the resonator, your exhaust will be significantly louder.
Old May 4, 2010 | 09:44 PM
HIValicious's Avatar
I have a rattle coming from underneath my car. I think it could be my cat? I don't know though. It happens when I'm idle &/or when I accelerate as well.
Old May 4, 2010 | 10:07 PM
Did you get an aftermarket flex installed?
I had a similar issue. When I had the new flex installed, it ended up being a bit longer than stock. The cat was rattling around against something underneath the car, so I ended up having them put some extra braces on the exhaust to keep it from rattling so much.
I think mine was rattling against the front sway, but I don't remember.
Old May 4, 2010 | 10:26 PM
Ryan07's Avatar
lemme say i have the same issues? as all above i fixed it with changing the rubbers in between the hangers problem was that with the heavy exhaust it just stretched mine out so i bought new ones and hasnt done it since... try it its fairly cheap amd very easy
Old May 4, 2010 | 10:28 PM
slowswap's Avatar
Check the heat shields if they're present.
Old May 5, 2010 | 07:04 AM
erackSS's Avatar
will i lose any boast by removeing my resinator? due to less back pressure
thanks
Old May 5, 2010 | 02:23 PM
Pollo's Avatar
I'm thinking about taking out my resonator, cause i'm almost at the end of my warranty.. can anyone tell me if I could loose any boost and power? thanks
Old May 5, 2010 | 02:37 PM
roser4888's Avatar
Originally Posted by slowcobaltisslow
careful with this. Loud exhaust will occasionally **** off cops. With out the resonator, your exhaust will be significantly louder.
it does **** off the cops, but in maryland as long as there is a cat, muffler and emissions are hooked up there isnt **** they can do.
I HAVENT NOTICED ANY POWER OR BOOST LOSS. HOWEVER WITH NO CAT AND NO RESINATOR IT DOES BACK FIRE ALOT MORE AND LOUDER. I LOVE IT
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
