Header and Downpipe
Header and Downpipe
im new to this forum and had a question... im looking to get a header and down pipe for the 2.0 LSJ and having a hard time deciding which is the best combo for cheap, can anyone help? im looking also to get stage 3 from ZZP next year with the 2.8" pulley which requires a downpipe and header. thanks
I would recommend looking into the zzp mid-length combo over the bad-mab set up. Its a little more but zzp quality is top notch. Even though bad-mab has is cheaper the flanges on the header are hit or miss.
do the zzp longtube combo. yea its around 600 but works great and is a thing of beauty. probably some of the best gains. sounds good too, check out my writeup.
https://www.cobaltss.net/forums/2-0l...0-well-281142/
im running a zzp long tube catless dp and zzp 3" exhaust it sounds amazing..very loud but mad huge gains over the other exhaust.
i would recomend to get a zzp long tube with a catted dp and a zzp 2.5" cat back exhaust. that should sound good and not be to loud. but u will get good percprmamce with the s3. zzps quality is very good. and they know how far to push the tune wen u get ur zzp s3..
z28addiction
Sep 28, 2015 12:03 AM
