Header and DP combo
Old Dec 17, 2007 | 02:04 PM
invisible's Avatar
Header and DP combo
Will I still get decent gain on just the header and Dp combo without getting the full exhaust system?? I was gonna get the magna-flow catback system also but i figured if i would still see decent hp gains just out of the header and dp combo then i would just go with that. Any advice will be helpfull. Thanks
I forgot to mension its the zzp header and dp combo.
Old Dec 17, 2007 | 02:08 PM
an0malous's Avatar
yes you will.
the header/dp is more restrictive than our stock catback.
but the catback will still help too.
chevysalesman614's Avatar
i would definitly get it, you can always have an exhaust fabbed up later.
Old Dec 17, 2007 | 02:11 PM
Formula96's Avatar
I found a thread fri. that showed how much cfm every part of the exaust flowed, and the part that was the most restrictive was the factory muffler....
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/flow-calculation-some-lsj-parts-67539/ The thread...
Old Dec 17, 2007 | 02:29 PM
invisible's Avatar
Well thanx for the info, i just ordered the header and dp. Would it be just as good if i custom made my own cat back system or will the magna flow be the best bet....when i say custom made i mean get a person who does exhaust to make it cause i no it would be cheaper but not sure if it would be as good.
Thanx for the advice.
Old Dec 17, 2007 | 02:32 PM
Formula96's Avatar
just make sure if it is custom you find some one who does mandrel pipe bending...
Old Dec 17, 2007 | 02:37 PM
invisible's Avatar
ok 1 more thing, is the ceramic coat really worth the extra 120.00
Old Dec 17, 2007 | 02:43 PM
Formula96's Avatar
no, send it to jet-hot...
www.jet-hot.com
ceramic has a tendancy to flake, i have had the jet-hot coated headers on my formula for 5 years and they still look brand new..... exept for where i bottomed out a couple of times.
Northindy
Oct 31, 2015 01:35 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
