which header/dp with my exhaust
Old May 3, 2008 | 06:00 PM
Sachemhockey44's Avatar
well im looking to make more power again right now i have a 07 ss/sc with stage 2, airbox mod and a gmpp performance catback and saved up some cash for a header/dp. My question is which header/dp would everyone recommend and especially which for my exhaust which is 2.25 inch piping unfortunately(wanted corsa but got a great deal on the gmpp). Thanks in advance.
Old May 3, 2008 | 06:03 PM
blk ss/sc 1's Avatar
zzp dp/high-flow cat.
and a gmpp manifold
Last edited by blk ss/sc 1; May 3, 2008 at 06:03 PM. Reason: Automerged Doublepost
Old May 3, 2008 | 06:04 PM
Littlegoose's Avatar
Most will say ZZP Midlength Header/DP Combo because of the "bang-for-the-buck" factor. I'm personally kinda leaning toward the CA V2 Header and XTC Downpipe myself. From the few videos there are that one seems to be a little less raspy than the ZZP but there aren't many videos to watch/compare and of the vids, some are bad quality. They are however a little more expensive.
EDIT: If you care about warranty go GMPP Header, but don't expect the same gains as another header.
Old May 3, 2008 | 06:06 PM
a header would void my warranty??
Old May 3, 2008 | 06:17 PM
xx07cobaltss24xx's Avatar
no a header will not void your warrenty ive been to the dealership many times with old 2.4 cobalt an i had a CA header XTC dp and a gmpp cat back along with a few other mods an they complained but did nothin haha
Old May 3, 2008 | 06:20 PM
RageTechnologies's Avatar
I would think so. But not totally sure. Most of the time it depends on the dealership and how lenient they are.
I like the zzp and vibrant header myself. Good design and material and they sound very nice IMO
Old May 3, 2008 | 06:23 PM
i dont think the gmpp will
Old May 3, 2008 | 07:13 PM
Well it shouldn't void your warranty if installed and operating properly, but they are more likely to warranty a gmpp part over an aftermarket part especially if its acting up, plus seeings as the header is a bit harder to install than say, intake or cat-back, there is more room for error on installation (if you plan on doing it yourself).
GM as a company and parts manufacturer knows their Extrude Honed Manifold is proven, works without error, gives increased airflow (however little it may be) and performance in conjunction with little to no negative effect on reliability. They do not know the quality/specifications of other products and cannot vouch for their craftsmanship and/or the effects that may result like they can with their own manufactured parts so there is CHANCE for less tolerance.
Just look at it like that I guess, from a business's standpoint to at least see why they may or may not cover something under warranty. You don't have to agree with it, but at least understand and respect the concept ya know?
EDIT: Straight from the GM Warranty found at:
http://www.crateenginedepot.com/pdfs...ne_Warrant.pdf
Originally Posted by Crate Engine Depot's Online Viewable Version of the GM Performance Engine Warranty
THIS WARRANTY DOES NOT COVER:
• Damage due to improper installation, negligence, alteration, accident,
improper use, or any use related to racing, track, or competition. Proper
vehicle use is discussed in the vehicle Owner’s Manual. In addition, coverage
does not apply if the odometer has been disconnected or the mileage reading
has been altered.
• Damage caused by lack of proper maintenance as described in the vehicle’s
original Owner’s Manual/Maintenance Schedule, failure to follow
Maintenance Schedule intervals, or failure to use or maintain proper type
and levels of fluid, fuel, oil, and lubricants recommended in the Owner’s
Manual/Maintenance Schedule. Proof of proper maintenance is the owner’s
responsibility. Keep all receipts and be prepared to make them available if
questions arise about maintenance.
• Damage as a result of overheating, contamination, or lack of lubrication.
• Damage caused by a turbocharger, supercharger, nitrous oxide, or similar
product, which is not an approved GM Performance Part or Accessory.
• Racing engines and/or their components.
• Use of components in excess of maximum torque specification.
• Damage as a result of modification/replacement of torque converter
that is part of transmission assembly.
• Loss of time, inconvenience, loss of use, or other economic loss.
• Vehicles registered and normally operated outside of the United States.
• This warranty does not apply to any unit installed under the General Motors
New-Vehicle Warranty.
Last edited by Littlegoose; May 3, 2008 at 07:14 PM. Reason: Added Quote from GM Performance Engine Warranty
Old May 3, 2008 | 07:20 PM
yea i got ya...i mean if i ever need work from the stealership ill just swtich and put the old header back on not really a big deal, my friend has a nice lift in his garage .... what sizes would i wanna go with either in vibrant or zzp for my exhaust ...and i dont want it to sound like **** rice...thanks
Old May 3, 2008 | 07:25 PM
KillerBee's Avatar
if your asking what size you wanna go with here are my suggestions
3" if you wanna make a lot of power like over 350hp or more
2.5 or so for 350 hp and under depends on what kind of hp you are aiming at.
Vibrant header and dp is a nice low deep sound i have it with my magnaflow and love it...
Old May 3, 2008 | 07:31 PM
okay thats what i want a deep sound not a raspy sound you know...something that sounds good and makes gains... i think ill go with the vibrant then... and i plan on making 300 if that all i am doing is intake, header, downpipe, catback, stage 2, custom tune and motor mounts....thats about all, maybe drop to a 3.0 pulley from the stage 2 one if its even worth it
will the vibrant header and dp with the 2.5 outlet fit nice with my exhaust??
Last edited by Sachemhockey44; May 3, 2008 at 07:31 PM. Reason: Automerged Doublepost
Old May 3, 2008 | 07:36 PM
KillerBee's Avatar
here is a clip of my complete exhaust
http://youtube.com/watch?v=XOjKEb0r0Aw
Old May 3, 2008 | 07:38 PM
stage2's Avatar
vibrant header downpipe
Old May 3, 2008 | 08:50 PM
Since you're planning on getting a tune, I'd probably recommend you get a 2.9 or a 2.85 instead of that 3.0 you're talking about (55-60$ shipped from Nate w/ new bolts ). Most of the time people recommend 60's if you go lower than that but those should both be safe for your injectors when you're tuned for them. I'd probably stick with a 2.5" exhaust on those mods too, you would probably push around 240-255whp with those mods I'd guesstimate.
Btw, I'd personally recommend the BWoody Solid Mounts. I can only attest to the Front Tranny Mount, but it's nice:
Solid Front Trans Mount Review
How To Install
Your exhaust sounds awesome.
Last edited by Littlegoose; May 3, 2008 at 08:50 PM. Reason: Automerged Doublepost
Old May 3, 2008 | 09:05 PM
KillerBee's Avatar
How To Install
thanks i love it too. best sounding exhaust i think
Old May 4, 2008 | 12:45 AM
rukkee's Avatar
With a GMPP exhaust any 2.5 downpipe should bolt up without issue . The stock DP has a 2.5 exit so you should be good to go.
Old May 5, 2008 | 01:03 AM
ssounds good im gonna order the vibrant header and dp when the money comes lol
Old May 5, 2008 | 01:36 AM
Eddie's Avatar
sounds nice. i dig it.
Old May 5, 2008 | 11:53 AM
KillerBee's Avatar
thanks sounds real nice
Old May 31, 2008 | 04:45 PM
JMac's Avatar
Just a question about this. So a 2.5" DP will connect to a GMPP exhaust? I thought GMPP is 2.25"? How does that work?
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
