Header install Question
When you are installing a Header onto your SS/SC, am I going to have to replace the Header TO engine gasket?
Does it rip off, or is it solid? Just wondering if I need to order a gasket???
Thanks!
Thanks!
I'm in the business of taking **** apart every day so I would reccomend also placing a small bead of red high-temp silicone around the ports on both sides of the gasket and fill the little breather holes in the head with it also. The gasket blocks them off anyhow. This will ensure a full seal.
z28addiction
Sep 28, 2015 12:03 AM
