Headers
Old Jul 16, 2009 | 01:45 PM
Hodz's Avatar
Headers
Will aftermarket headers affect how lean/rich the car runs?
Old Jul 16, 2009 | 02:32 PM
Snakes709's Avatar
nope. As far as i know it wont effect anything...i know if u are installing header/dp. When you start the car up for the first time u have to let it settle and let the wideband get use to the new air flow
Old Jul 16, 2009 | 02:54 PM
Frew's Avatar
--x2
Old Jul 16, 2009 | 02:56 PM
BLAZIN07SS's Avatar
I'm too JDM for you
let the wideband get used to the airflow? what?
and yes a high flow header and downpipe will lean the car out a little, my car went from 10.0 on the wideband to 10.9-11.0 AFR at wide open throttle
Old Jul 16, 2009 | 03:40 PM
Zach06CobaltSC's Avatar
Wow, a whole point that seems like a lot, although the stock setup is pretty restrictive. Depending on what your running now op, if you go with a new exhaust setup you will run a little leaner, however it doesn't appear that your tuned so don't worry about it. The gm stage 2 tunes run EXTREMELY rich so the leaner you can get them the better.
Old Jul 16, 2009 | 04:35 PM
Frew's Avatar
what i ment to agree with was the stock stage two tune is rich even with a 2.9 and cti header three inch downpipe-back i was still running 10 flats
Old Jul 16, 2009 | 04:51 PM
Snakes709's Avatar
what i ment was (this is what i was told because ill be installing new header/dp/exhaust in a few weeks)...is that when the car starts up for the first time the a/f is abit jumpy so u have to let it idle abit then it will calm down.
Old Jul 16, 2009 | 05:25 PM
Hockeyman's Avatar
A smaller pulley will not necessarily lean you out, your maf will read all the new airflow coming in and proceed to dumping more fuel in to keep you at the commanded afr.
Old Jul 16, 2009 | 06:04 PM
Area47's Avatar
Rent me! per hour
not always
just depends on how the maf scaling is setup
Old Jul 17, 2009 | 01:55 AM
SilverSS_TNR's Avatar
the op is proly the coolest guy u will ever meet
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
