Headlights Install
Two bolts for each headlight on top of them. They are holding down the black part of the housing down. Remove bolts, and then wiggle out at an angle. You'll figure out what I mean with the wiggling. Disconnect the electrical connector. Take out healight assembly, and replace bulb. You may need to twist or do something to get it out (can't remember). Then replace the light and tighten down. Really simple actually.
Delta coupe
Sep 30, 2015 08:11 AM
