heat exchanger
Old Nov 10, 2006 | 07:53 AM
soccer1061287's Avatar
At the risk of being redundant, I would suggest that without a pressurized intake, which significantly heats the charge air, you will likely run higher charge air temperatures with the intercooler and natural aspiration. My recommendation would be that if you want to get some of the preliminary work done prior to doing the SC, go ahead and install all of the correct components, but do not run the pump or fill the system until you have a need for it. I do not know if that is possible, because I don't know if the pump is gear or belt driven and if belt driven, can it be there and not hooked up. Don't get discouraged, but also make sure you are being clear and complete with your information and questions.
Old Nov 12, 2006 | 05:54 PM
redsuperchargedgirl's Avatar
Originally Posted by Cobalt_Supercharged
Not bashing here. It will not get any colder than ambient which is the same temperature that will be coming through your intake while NA. I understand you will be going with the supercharger as soon as tuning is available, but you may want to wait because the cores will create restriction and would rob you of HP. Wait until you get the tuning and the S/C installed.
It won't get any colder than ambient unless it's air to water!
Old Nov 12, 2006 | 06:47 PM
Blown 4-banger's Avatar
No it still won't, because the water also has to be cooled, which is cooled by ambient air. The water won't get colder than ambient air so the air won't either.
The pump for the intercooler fluid is electric and doesn't use a belt.
Old Nov 12, 2006 | 11:10 PM
Cobalt_Supercharged's Avatar
Unless you add ice or a CO2 fogger to the HE you will gain nothing. Even still it is an air restriction.
DarrenGC
Dec 24, 2021 01:55 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
