heat exchanger?
Old Dec 9, 2007 | 10:32 PM
Deersniper17's Avatar
heat exchanger?
about to buy and install a cobra h/e...i was thinking...would it be a good idea if instead of completely bypassing the stock one...could i just run a coolant line off the return side of the stock one into the the feed side of the cobra and run the return side of the cobra to the return on the pump.....good idea...idk opinions welcome
Old Dec 9, 2007 | 10:35 PM
an0malous's Avatar
thats what everyone already does bro
the purpose of the H/E mod is to increase the cooling fins, and volume of coolant, in the system.
would be silly to bypass the stocker.
Old Dec 9, 2007 | 10:36 PM
spaz's Avatar
What he said^^
Old Dec 9, 2007 | 10:39 PM
anthonyS88's Avatar
yes the more coolant kinda the better
Old Dec 9, 2007 | 10:41 PM
Coblt ss super's Avatar
how do u bleed that dam system tho?
ooooooooo lol i for some reason people just forgot about the stock one and went with a smaller more direct cooling area...and i thought i was cutting edge lol.....dont i feel dumb : ) to bleed the system it will in theory do it by iteself as long as u fill up the heat exchanger with dex b4 u install it and air will exscape through the fill..or at least i think so....its too late for me to be awnsering questions lol
Old Dec 9, 2007 | 10:44 PM
anthonyS88's Avatar
your not dumb, (only saying that bc you live in nassau county where i was born lol)
Old Dec 9, 2007 | 10:50 PM
what part....its a big place lol
Old Dec 9, 2007 | 10:53 PM
anthonyS88's Avatar
bethpage. but my dad was born and raised in west islip
Old Dec 9, 2007 | 10:56 PM
i ehard if u throw the h/e on you fill it from the fill, and turn the car on itll run the pump and u keep adding dexcool till it like gets rid of all the air
Old Dec 9, 2007 | 10:57 PM
an0malous's Avatar
thats how I did mine.
but instead of starting the car i just jumpered the relay for the IC pump same as i do at the track.
saves wasting gas.
Old Dec 9, 2007 | 11:02 PM
saves wasting gas.
haha u dont waste that much gas at idle u cheap bastard!!! haha jk
Old Dec 9, 2007 | 11:03 PM
an0malous's Avatar
well it took about an hour to get it completely topped up....
Old Dec 9, 2007 | 11:05 PM
and wouldnt it also get hot? how do you jump the relay?
Old Dec 10, 2007 | 12:25 PM
Sachemhockey44's Avatar
whats the heat exchanger do for the car performance wise, is it worth it, and would it void my warranty lol thanks
Old Dec 10, 2007 | 12:56 PM
CJ BadBlackSS's Avatar
Cools the charged air better, yes, and yes.
Old Dec 10, 2007 | 01:01 PM
fsickness's Avatar
I think the best way I have herd it put on here as far as the H/E goes is....
You add more coolant to your system, just like adding more water to a pot on the stove it will take longer for it all to heat up and since you are adding the H/E it also gives more of a surface area for the coolant to cool off.
^^Think that about sums it up....?....
Old May 28, 2008 | 12:48 PM
XCRuna1201's Avatar
So what your saying is hook it all up while it is still empty. Once it is bolted up you poor the dexcool into it up to the top then turn the IC Pump on to take it in....the level will go down and you keep filling it until the level of coolent does not drop in the heat exchanger?
DarrenGC
Dec 24, 2021 01:55 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
