heat exchanger bleed
Old Apr 6, 2014 | 07:18 PM
09cobalt 2.2's Avatar
is there any way to tell if I have all the air out of the heat exchanger system I have zzp s3 option b kit and duel pass
Old Apr 6, 2014 | 07:53 PM
Old Apr 6, 2014 | 08:35 PM
08G5GT2.4L's Avatar
if you have option b then its self-bleeding.
Old Apr 6, 2014 | 09:22 PM
but the zzp s3 doesn't have any bleeders on it and I don't have the stock lsj heat exchanger (supercharged 2.2)
Old Apr 6, 2014 | 09:37 PM
Dyn0mitemat's Avatar
You'll have yo put one on it then
Old Apr 6, 2014 | 09:43 PM
mrbelvedere's Avatar
use the search button
Old Apr 6, 2014 | 10:20 PM
been using the search button but cant find anything on bleeding the zzp s3
Old Apr 7, 2014 | 07:26 AM
Staged07SS's Avatar
Administrator
Administrator
You dont have opt b than if it's not hooked up.
Pick up a stock lsj h.e., or have some one weld a bleed fitting on to the top of your zzp h.e.
It's difficult to remove all the air from the coolant w/o opt b. Pick up a scan gauge to monitor IAT's as well.
Old Apr 7, 2014 | 08:45 AM
You only have the stg3 h/e? That little one? Def get a stock lsj one to use in parallel with it
Old Apr 7, 2014 | 01:58 PM
josh6854's Avatar
Where would you put the bleeder on the h/e and why not just run it without the stock h/e?
DarrenGC
Dec 24, 2021 01:55 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
