Heat Exchanger Help
Old 08-14-2007, 03:19 PM
Freakenhye's Avatar
Heat Exchanger Help
I want to get a heat exchanger. I know about the CA heat exchanger, and a Cobra Heat exchanger. But other then that what else can i get.
I want something with more coolling capacity then the stock Cobra or the CA.
i dont want to do any mods on the front end. Just basicly bolt on.
Has anyone used any heat exchangers other then CA, and Cobra?
Old 08-14-2007, 03:54 PM
Matty's Avatar
I have a Fluidyne. It is an upgrade for the Cobra Mustangs. It is a 3 row.
http://www.fluidyne.com/pl_intercoolers.html
Old 08-14-2007, 04:26 PM
Freakenhye's Avatar
Is this a exact replacement for the Cobra heat exchanger but its a three row.
Is the cobra heat exchanger a 2 row?
Old 08-14-2007, 04:43 PM
Matty's Avatar
It is 2 inches shorter than the Cobra. In the Fluidyne literature that comes with it they say that due to their improved design they were able to make it shorter. It is thicker though and it is a tight fit.
http://www.whipplesuperchargers.com/...sp?ProdID=1218
I am not 100% sure if the stock Cobra is a single or dual pass.
Old 08-14-2007, 04:59 PM
Freakenhye's Avatar
can you take pics of your install and show them. I would like to see it. Thanks.
Old 08-14-2007, 05:04 PM
Rodimus_Prime's Avatar
whats the cheapest place to pick up that fluidyne
Old 08-14-2007, 05:05 PM
BlilBT's Avatar
Here is a few pics of the 1 I got, It is Dual pass 2 1/2 inches wide, 7 inches High & 30 inches Long fits No Problem!
Here is a shot with the grill off!
Old 08-14-2007, 05:21 PM
ridemlow03's Avatar
is that the fluidyne exchanger???
Old 08-14-2007, 05:26 PM
BlilBT's Avatar
It Is Like them but Not theirs, I got it in a Group Buy! Only 13 were made, but it shows you it will fit No problem! I had to make the mounting brackets which is No Big deal either, You simply go to home depot & Buy some stock Flat Aluminum!
Old 08-14-2007, 05:29 PM
ridemlow03's Avatar
ohh ok but its the same size then. thats cool looks good man.
Old 08-14-2007, 05:32 PM
BlilBT's Avatar
I Believe it is really close to the same size & TY!
Old 08-14-2007, 06:43 PM
Maxim_X's Avatar
What mods make you want more cooling power?
From my experience the coolant doesn't really heat soak to easily unless you have dual pass or something. Ussualy an extra H/e is a compliment to a dual pass intercooler it barely does anything alone.
Old 08-14-2007, 07:28 PM
BlilBT -where you get that, does it hang out from under the bumper at all its hard to see in that pic, is that a bleed screw I see on top there?
Old 08-14-2007, 08:59 PM
BlilBT's Avatar
I got it last year, No it does not Hang down at all! The bleeder was replaced with a Plug & It sits on the Bottom Passenger side & Man does it make it easy to drain & fill the System! I also made the Brackets from stock Aluminum & Mounted it on Rubber Bushings for Vibration & Shock Adsorbtion!
I'm Running the GM Dual Pass (Option B) with a Custom made Expansion Tank! Alot of what my car has is custom made, Most good Radiator shops can Fab you up what ever you want!
BWOODY made this for me, Of course I had to draw it up 1st!
Old 08-14-2007, 09:08 PM
Matty's Avatar
Old 08-14-2007, 11:52 PM
Freakenhye's Avatar
Thanks for the pics.
Old 08-15-2007, 12:03 AM
ItalianJoe1's Avatar
The H/E you have looks just like the C/A one, are you sure its different? Even has the same bleeder fitting in the exact same place.
I have the C/A one, its awesome and looks great on the car. To the OP, why are you needing to go bigger?
BTW: Yay me, 1500 posts!!! :
Old 08-15-2007, 12:05 AM
Freakenhye's Avatar
What do you think about this one.
http://www.lightningforceperformance...bra-p-319.html
Old 08-15-2007, 12:15 AM
its 7 inches deep theres some concern about fitment, i saw in another thread someone was goign to try it
Old 08-15-2007, 12:25 AM
Shortbus's Avatar
yea i made the thread about the lfp dual pass.
Old 08-15-2007, 12:36 AM
whats the deal on that anyway
Old 08-15-2007, 12:43 AM
That looks like a little overkill. Whats wrong with the other ones availible?
Old 08-15-2007, 11:17 AM
Freakenhye's Avatar
Did you ever try the LFP one.
I talked talked to LFP and there dual pass heat exchanger is
29" 3/4 lenght
6" height
2" 1/2 width
It also has a bleeder valve so i went ahead and ordered it.
Old 08-15-2007, 03:36 PM
CobaltSS313's Avatar
29" 3/4 lenght
6" height
2" 1/2 width
i just got off the phone with Mike from LFP, i told them about the cobalt SS/SC community about their need for a good H/E and how everyone has been buying up stock cobra h/e. I told him about the 1/4 bung that needs to be welded on top of the H/E incase someone is running the dual pass option B with the extra coolant bottle. So he said that mark and he will talk about it and let me know. I told them that I would be willing to make the brackets and send the a set so they can make them and sell them with their kit. They also said when the kit is finished it will be completely bolt on assembly with everything included.
Old 08-15-2007, 04:40 PM
SteelCharger's Avatar
Now this is what I like to hear!!
Quick Reply: Heat Exchanger Help
