heat exhcahnger ?
Old Sep 2, 2010 | 07:30 PM
NOLAGSS's Avatar
heat exhcahnger ?
my pump went bad and am ordering a new on tommoro and my question is.. as of now i have both factory and aftermarket hooked up right now. when i drain all the coolant and install the new pump should i leave my set up how it is or just run the cx heat exchanger. and gains pros cons. like easier to get air out of system or cooler temps from only running one h/e. any input is appreciated.
Old Sep 2, 2010 | 07:41 PM
Bluelightning's Avatar
Got Bewst?
Leave them both. For easier bleeding get an option b
Old Sep 2, 2010 | 11:46 PM
Bika's Avatar
Fail Less.
This^^^
Old Sep 3, 2010 | 04:54 AM
MrSlickSter06SS's Avatar
How did you notice you had to change the pump..? No pressure in the lines..?
Old Sep 3, 2010 | 04:55 AM
06arrivalSC's Avatar
Probably iat2s through the roof...just like me right now lol
Old Sep 3, 2010 | 05:07 AM
humm good point, damn I gotta get a aeroforce... I dont have one but I just did and opt b. kit and ottp 4th gen h/e setup on my car but I have no pressure in the lines so one guy said in another topic that I had posted that maybe my intercooler pump went out, and said they usually go out in 2 years in my year of cobalt... not sure if its true havent heard much about this but yeah... I am also trying to find a color diagram or something to show the routing of the opt. b. kit without dualpass, do you know of one?
Old Sep 3, 2010 | 03:59 PM
NOLAGSS's Avatar
no i noticed it because i dont have any flow in the filler neck but if i tap the pump it starts to flow
Old Sep 3, 2010 | 06:48 PM
Got Bewst?
An option b makes it real nice to tell 100% if you're pump is working or not because it constantly bleeds the system. The bleeder line is clear so you can see the coolant flowing
Old Sep 3, 2010 | 06:57 PM
scotch89's Avatar
if i was you, i would pinch the line going in and out of the pump. so you dont have remove all the coolant....just a thought.....use vise grips but put somthing between the teeth and the hose so u dont damage anything.
Old Sep 3, 2010 | 11:53 PM
NOLAGSS's Avatar
stupid question but can i do option b with out a dual pass? iv researched it alot and found nothing but opt b with dual pass
Old Sep 5, 2010 | 05:27 AM
Black SS/SC 06's Avatar
Yea that works pretty good.
Old Sep 5, 2010 | 10:46 AM
NOLAGSS's Avatar
never thought of that thats actually a good idea.. at work when i do calipers we have these tools to pinch the brake line so all the fluid dont run out ill use one of those well two of them. plus one for u on saving me the damm hassel of bleeding out the air
Old Sep 5, 2010 | 11:33 AM
395 plus's Avatar
I have the same question??
Old Sep 5, 2010 | 04:46 PM
I am pretty sure you can. I would ask ZZP or OTTP to be sure though.
Old Sep 6, 2010 | 02:53 AM
Yea the aeroforce can literally be a lifesaver, now after having one, i wouldnt drive a day without it; i have no idea where you can find a diagram with routings of the option b without the dual pass
Also, to everyone else, ive never noticed coolant visible in my filler neck...does this mean i can add some more coolant/water to the system so that it will be visible in the filler neck and then ill be able to tell for sure if the IC pump is working aka ill see if coolant bubbling/jumping around/flowing
Old Sep 6, 2010 | 03:47 AM
jrzdude's Avatar
Yes, you can. All you do is remove the filler neck and replace it with a "T" fitting. Now you have an extra hose fitting. You then run the 3/4" hose from the Opt B tank to that fitting.
Then for the bleeder hose, you just tap into the bleeder screw on the HE and run that to the Opt B tank...Done
DarrenGC
Dec 24, 2021 01:55 PM
Sean Cummings
Jan 8, 2020 10:17 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
jmelton327
Sep 26, 2015 10:04 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
