Helicoil odds of fix?
Old Apr 13, 2009 | 06:20 PM
Sh0nuff's Avatar
Ok you uber-SS/SC guys I need some help....
So changing my spark plugs the other day I get to #3 it's kinda hard coming out.
So I get it out...SURPRISE it's got a helicoil attatched to it. Now before this my car went from sounding normal to a more throaty exhaust sound hence why I decided to change plugs.
I end up just screwing the damn thing back in and the sound is back to normal, but I don't trust it.
Called a mechanic friend he said get another helicoil stick some jbweld on it screw it in let it set a day
then put your plug in, and hope all is well.
I Called a dealer they say they can put something better then a helicoil in, it's called a
TimeCert?
Anyway they say there is no gurentee and will cost $300 ..depends on what has been done so far.
Of course if neither works then it's a new head for me....
So a couple of questions...
1. Anyone have any dealings with this TimeCert?
2. What are the odds of either of these working?
3. Where to get a new head and how much do they run?
Thanks guys I appreciate it!
This is not the kind of surprise that I like to recieve
Old Apr 13, 2009 | 06:35 PM
Maxim_X's Avatar
I've never heard of a time-cert.
But I would trust the helicoil. If it's back to normal forget about it and hope for the best. I stipped my head recently and that will be my fix/
Old Apr 13, 2009 | 06:41 PM
Sh0nuff's Avatar
Yeah I have never heard of it either, they said they drill it out, put in this sleve and adhere it to the head let it set and seal and it's as good as new, doesn't sound much different then a helicoil in my book but they said it was.
It doesn't thread in atleast from what it sounded like, it is more like a incert.
Old Apr 13, 2009 | 06:43 PM
chris88z24's Avatar
You know the engine has to be COLD (as in has been sitting all night and not started) before you can remove the plugs, right?
Old Apr 13, 2009 | 08:50 PM
Sh0nuff's Avatar
The car was setting for 2 days before I changed them. So that couldn't have been a factor...
Not to mention it sux to buy a car and 5 months later find something like this out lol.
Any other help guys?
Old Apr 15, 2009 | 06:15 PM
Sh0nuff's Avatar
Ok so I went looking for a helicoil today...
No one seems to carry one the lenth of our plugs...
anyone know anywhere that does?
Old Apr 15, 2009 | 06:20 PM
TSweet88's Avatar
Ya a timecert basically replaces the material which was removed, its pretty commonly used just not as popular as a heli-coil
Old Apr 19, 2009 | 09:26 PM
Sh0nuff's Avatar
Well my car is going to vandergriff chevy in the morning for a timesert wish me luck.....
after reviewing the specs on timeserts they seem like a much more perminant fix with not much of a failure chance..
Old Apr 19, 2009 | 09:49 PM
SSdan's Avatar
I do mine cold or hot. Don't matter to me
Old Apr 19, 2009 | 09:53 PM
twzted's Avatar
motors are going cheap, check a local junkyard...buddy just picked up an LSJ for $300(supercharger was dmged) but the motor was fine
Old Apr 19, 2009 | 10:00 PM
ufnwish's Avatar
i had that same problem with a 87 z24 it didn't last very long best of luck
Old Apr 20, 2009 | 07:21 PM
Sh0nuff's Avatar
So I called and they said that everything went smoothly and it's all back together they want to keep it over night to make sure everything sets and seals so i can pick it up in the morning
Old Apr 20, 2009 | 08:05 PM
Maven's Avatar
Time-Serts are the way to go, they arent just a coil like a Helicoil, they are a complete piece of material(imagine a bolt with a threaded hole on the middle for another bolt to go into), its the GM recommended thread repair method, its actually stronger than the original joint in most applications. The reason they are less common than HeliCoils is because they are more expensive, the Time-Sert itself is more expensive than a Helicoil and theres also dedicated tools that go with it, not some plastic can opener like a HeliCoil, LOL. I love Time-Serts.
Old Apr 20, 2009 | 09:44 PM
Sh0nuff's Avatar
yeah i went to the time-sert website and the videos are what made my decision!
Looks like a quality product.
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jmelton327
Sep 26, 2015 10:04 PM
