Help.........
Actually it means he's at 84 - 87mph thats were the Flux capacitor pulses causing misfire readings.
Once you hit 88 it hits straight pulse and that error will go away. Aeroforce will relase an update for it on 2/24/2087 so time travel there to get the fix.
I told you what the problem is. In the ad campaign (Back to the Future) you see the Delorean get to bout 83mph and it starts pulsing and sparks start coming off the car as the Flux Capacitor is reaching the point of singularity displacement (time travel) and then at 88mph the pulse stops and goes solid and the car makes the time jump. This is inherent in the Flux Capacitors design and can not be fixed but when it does this the Aeroforce Interceptor freaks out believing it to be a misfire on the number 5 cylinder.
Your car is fine. The update to the Aeroforce is coming out in 2087.
