Help 2.8 PB install
Old Nov 5, 2006 | 02:25 PM
Woodyr007's Avatar
Help 2.8 PB install
Hey guys I have searched for about 10 min and I cannot find much help can anyone tell me how to do this. I have the bit from the STG 2 kit. I dont know where to push on the tensioner, and when I try to loosen the bolts the pulley spins. I know duh. Any help? Thanks
Old Nov 5, 2006 | 02:29 PM
patathSS's Avatar
You need to loosen the bolts with the belt tension still on. If you ae doing that then damn those bolts are way too tight.
Old Nov 5, 2006 | 02:33 PM
Woodyr007's Avatar
Yes the belt is still on and the pulley is spining, should I put it in gear?
Old Nov 5, 2006 | 02:44 PM
Woodyr007's Avatar
Aso, maybe I am retarded but where do you push on the tensioner cause im trying AND NOTHIGN IS MOVING
Old Nov 5, 2006 | 02:55 PM
2K5SS/SC?'s Avatar
Do you have the instructions that cam with the Stage 2 kit? It shows exactly where you need to put the 15mm wrench on the tensionser. It's the squared hump that's on top of the tensioner. Put the wrench on, and push down and toward the front seats, and the tension will be released allowing the belt to be removed.
If the tension on the pulley is not enough to keep it in place, you may have to take the belt off and use strap wrench to get the job done. You could also have a friend hold the belt even tighter around the pulley while you try to remove the bolts. Good luck.
Old Nov 6, 2006 | 11:48 AM
leviticus88's Avatar
Leave the tension on the pulley and use a prybar to put pressure between the tensioner and the pulley. That should hold the pulley in place.
Old Nov 6, 2006 | 01:19 PM
fr33k's Avatar
Here's some pics that might help you out in finding where to put the 15mm open end wrench.
and:
Old Nov 6, 2006 | 02:25 PM
The black line would be the pry-bar (crow-bar, etc). It puts pressure on the pulley and wont let it spin.
Also, the pulley boys tension tool is amazing! I can change my pulley in -15 mins. by myself.
Again, good luck!
Old Nov 6, 2006 | 03:46 PM
ReMz's Avatar
Hopefully ur dealer didnt over tighten the bolts like on my stage 2 install. that was a pulley removal from hell.
Old Nov 6, 2006 | 06:24 PM
Woodyr007's Avatar
Thanks guys ya ended up that one was too tight to get off, guess I will have to take another shot at it when I get the right tools.
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
SlowSaturn
Sep 28, 2015 11:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
