Help???
The stage two KIT has 42lb injectors and a shorter belt and differnet tuning. I wouldnt run the pulley with out the rest of the stuff to support it unless you like broken parts.
Items needed
1 Stage 2 belt or different tensioner pulley (belt is easier to do)
2 42 lb injectors
3 PCM tuning
Items needed
2 42 lb injectors
3 PCM tuning
i remember reading a long long time ago back on css dot com
that if you throw a smaller pully on there along with a manual boost controller and keep it at stock boost that you can get some pretty good gains. not necessarily in over all HP but you get the power alot sooner
i read that like 5 years ago tho
might possibly mess some stuff up..... might..... but, I don't think there would be that much of a gain, because the car would not have a tuned ecu therefore would not see the new mass of incoming air. Most likely run lean as well.
Sit back, and read some before you start telling other new guys to do **** to their cars that will end up with them blown up.
might? I think its a given that it will. The stock tune and injectors arent designed to run a pulley that small.
never told him to do anything. read my post 1 more time. when did I say " ya, do it, itll be great. speed racer will be jealous 'aha', please f$&% up your pistons and float your valves 'aha'." go speed racer "aha".
what the heck does dropping a pulley size have to do with valve float?
general look, most cars have a bit of valve float naturally. Idk why karlen thinks he knows everything. a lsj is just like every other engine out there...you think mechanics look at it and go "ohh its a sc lsj chevy cobalt, Im going to have to go get some extra schooling before I can diagnose this car".. ya, no, all engines are the same. just because a punk kid (not going to mention anyones name) can climb under a car and put some little mods on it, doesn't mean he's an expert. thanks., and to end this thread and help a brother out. DO NOT PUT ON THAT SMALLER PULLEY.
thanks karlen89 your a real hero.
