Help???
Old Apr 4, 2010 | 12:05 AM
osocool1's Avatar
Question Help???
stage2 pulley on stock everything???? good or am i going to blow my motor??? help please
and what am i going to need to run this????
Old Apr 4, 2010 | 12:11 AM
Caligula's Avatar
My friend put a stage 2 pully on his stock cobalt and the car started playing ricky martin music, then blew up.
Old Apr 4, 2010 | 12:15 AM
Karlen89's Avatar
Search feature broken around here or what?
Old Apr 4, 2010 | 05:48 PM
395 plus's Avatar
The stage two KIT has 42lb injectors and a shorter belt and differnet tuning. I wouldnt run the pulley with out the rest of the stuff to support it unless you like broken parts.
Items needed
1 Stage 2 belt or different tensioner pulley (belt is easier to do)
2 42 lb injectors
3 PCM tuning
Old Apr 4, 2010 | 05:52 PM
nicksredline's Avatar
/\ all stated above is true take that pully off before u blow her up bud.
Old Apr 4, 2010 | 06:19 PM
selfinfliction's Avatar
don't listen to them, put the pulley on, and then add a 50 dry shot of NAWWWWWWWWS for warp speed!!!
Old Apr 4, 2010 | 09:27 PM
Supercharged06's Avatar
i remember reading a long long time ago back on css dot com
that if you throw a smaller pully on there along with a manual boost controller and keep it at stock boost that you can get some pretty good gains. not necessarily in over all HP but you get the power alot sooner
i read that like 5 years ago tho
Old Apr 4, 2010 | 09:39 PM
osocool1's Avatar
bump tanks for all info and smart ass com.
Old Apr 4, 2010 | 10:05 PM
Karlen89's Avatar
No problem sweetheart.
Old Apr 4, 2010 | 10:52 PM
northvibe's Avatar
please inform us why you think running a Stage 2 pulley WITHOUT the other stage 2 parts is a good idea?
Old Apr 4, 2010 | 11:01 PM
Karlen89's Avatar
Because he's got $40 to spend on his car, and he wants to go fast!
Old Apr 4, 2010 | 11:39 PM
he wants to go fast!!!!!!
Old Apr 5, 2010 | 12:06 AM
Karlen89's Avatar
aAHAHAHAHAHAHAHAHA
That's the greatest ricky bobby picture ever.
Old Apr 5, 2010 | 12:10 AM
ecot3c inside's Avatar
might possibly mess some stuff up..... might..... but, I don't think there would be that much of a gain, because the car would not have a tuned ecu therefore would not see the new mass of incoming air. Most likely run lean as well.
Old Apr 5, 2010 | 12:14 AM
Karlen89's Avatar
I may not be the smartest guy around here, but there's probably 5 posts on top of yours saying not to do it.
Sit back, and read some before you start telling other new guys to do **** to their cars that will end up with them blown up.
Old Apr 5, 2010 | 12:29 AM
northvibe's Avatar
might? I think its a given that it will. The stock tune and injectors arent designed to run a pulley that small.
Old Apr 5, 2010 | 11:05 AM
never told him to do anything. read my post 1 more time. when did I say " ya, do it, itll be great. speed racer will be jealous 'aha', please f$&% up your pistons and float your valves 'aha'." go speed racer "aha".
Old Apr 5, 2010 | 11:25 AM
what the heck does dropping a pulley size have to do with valve float?
Old Apr 5, 2010 | 11:35 AM
Karlen89's Avatar
Watch out man..this guy has owned his car for a week, and knows everything about it. Drop pulleys, don't change ****. MAKE MOAR POWERZ!
Old Apr 5, 2010 | 06:23 PM
general look, most cars have a bit of valve float naturally. Idk why karlen thinks he knows everything. a lsj is just like every other engine out there...you think mechanics look at it and go "ohh its a sc lsj chevy cobalt, Im going to have to go get some extra schooling before I can diagnose this car".. ya, no, all engines are the same. just because a punk kid (not going to mention anyones name) can climb under a car and put some little mods on it, doesn't mean he's an expert. thanks., and to end this thread and help a brother out. DO NOT PUT ON THAT SMALLER PULLEY.
thanks karlen89 your a real hero.
Old Apr 5, 2010 | 06:31 PM
Karlen89's Avatar
**** yes I am. Bow before your master.
Old Apr 8, 2010 | 07:26 PM
osocool1's Avatar
Old Apr 8, 2010 | 07:45 PM
Frew's Avatar
hahaha, why did he bump the thread?!?! Put the pulley on, make more boostz, make moar powarz
Old Apr 10, 2010 | 10:36 PM
osocool1's Avatar
um its my thread so i can bump all i want bump bump bump.... and bump
Old Apr 11, 2010 | 10:34 PM
Frew's Avatar
you thread is a joke, hence why I said the above
