Help
The only person that I know well enough to trust with working on my car is in Ohio around Dayton.
How did you time the cam hex? Did you replace the sensor itself?
I'd work on getting that right before trying to solve the other problems. Misfires are almost always either plugs, coil packs, or injectors.
Timed it number one and the mark on housing and number four and four o’clock also my guy checked timing and said it was dead on. Did not change sensor. The thing is that these codes came up on two different motors and two different ecm’s. Also has an off ideal hesitation.
