Help asap
Revised.
If the car can crank over and he has jumped it and it stil won't start.battery is out of the question. A car needs 12 volts to start correct and to run it uses the aternator so he needs to check for fuel and spark.
Hey blazin if the coolant says -40 and ambient isn't. Either sensor is bad or pcm is. But if sensor was bad it would still start with a bad sensor. Op needs o help us diag his car like. Take a coil off the cr with a spark test and see if it has spark but take the injection harness off before this is done. Fueling check fuel pressure. If good. See if injectors are spitting. By taking them out of the head or intake mani.
But blazin is correct we need answers... btw blaze I still ove ure car lol.
Last edited by Chevycobaltss3; Dec 20, 2010 at 09:33 PM. Reason: Automerged Doublepost
If ure car can turn over then its not ure battery. If it can't crank even if u have 12v + and all it does is click. Check ure ip signal fuse in the fusebox. If it can crank check fuel and spark.
^^^wtf to cold to start. Hmmm. No...... what he needs to do is listen to people who know what there talking about. Check fuel and spark bro if u need help please give me a call or text 2705053212. James.
If he disconnects pcm then he wil still have his issue. Al he is doing is making the pcmrelearn itsef. If it did start after he did this then he was either in security mode to where it wont let his car start or he had a connection issue.
So issue wouldnt be fixed.e
Last edited by Chevycobaltss3; Dec 21, 2010 at 11:55 AM. Reason: Automerged Doublepost
