Help asap
Old Dec 20, 2010 | 09:23 PM
BLAZIN07SS's Avatar
I'm too JDM for you
temp gauge says -40 or does the coolant temp say -40?
asking the question again
Old Dec 20, 2010 | 09:27 PM
Chevycobaltss3's Avatar
Revised.
If the car can crank over and he has jumped it and it stil won't start.battery is out of the question. A car needs 12 volts to start correct and to run it uses the aternator so he needs to check for fuel and spark.
Old Dec 20, 2010 | 09:33 PM
Hey blazin if the coolant says -40 and ambient isn't. Either sensor is bad or pcm is. But if sensor was bad it would still start with a bad sensor. Op needs o help us diag his car like. Take a coil off the cr with a spark test and see if it has spark but take the injection harness off before this is done. Fueling check fuel pressure. If good. See if injectors are spitting. By taking them out of the head or intake mani.
But blazin is correct we need answers... btw blaze I still ove ure car lol.
Last edited by Chevycobaltss3; Dec 20, 2010 at 09:33 PM. Reason: Automerged Doublepost
Old Dec 20, 2010 | 10:46 PM
CanadianCobalt's Avatar
Originally Posted by Chevycobaltss3
Revised.
Finally.
Thank you!
Joel
Old Dec 20, 2010 | 10:55 PM
C_A_D88's Avatar
ive tried jumping my car from under the hood...no luck, ive tried jumping a car from under the hood no luck, gotta go straight to the battery....?
Old Dec 21, 2010 | 01:40 AM
If ure car can turn over then its not ure battery. If it can't crank even if u have 12v + and all it does is click. Check ure ip signal fuse in the fusebox. If it can crank check fuel and spark.
Old Dec 21, 2010 | 08:58 AM
05Blackss.sc's Avatar
try reseting your pcm. it probably thinks its to cold to run. did you try unplugging your battery. try the easy things first so you dont waste your time and money buying a new batt
Old Dec 21, 2010 | 11:21 AM
^^^wtf to cold to start. Hmmm. No...... what he needs to do is listen to people who know what there talking about. Check fuel and spark bro if u need help please give me a call or text 2705053212. James.
Old Dec 21, 2010 | 11:51 AM
well worked for me......
Old Dec 21, 2010 | 11:55 AM
If he disconnects pcm then he wil still have his issue. Al he is doing is making the pcmrelearn itsef. If it did start after he did this then he was either in security mode to where it wont let his car start or he had a connection issue.
So issue wouldnt be fixed.e
Last edited by Chevycobaltss3; Dec 21, 2010 at 11:55 AM. Reason: Automerged Doublepost
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
