help with a build
Old Sep 18, 2013 | 01:15 PM
ssboltorange's Avatar
help with a build
Ok I have a 2006 ss/sc I want to do some minor upgrades
-2.8 pulley
-60lb injectors
-smaller belt
-tune
-heat exchanger
now my questions at do I need a huge heat exchanger or can I use the one that comes with zzp stage 2 kit? Also what type of power increase should I be expecting? Last I have 98000 on my ss is it too late to be doing all of this? And I want to hear some opinions on wheather I should get a trifecta or h.p tune
thanks in advance
Old Sep 18, 2013 | 03:30 PM
mrbelvedere's Avatar
your not doing a build
Old Sep 18, 2013 | 09:15 PM
ok please help with my very small project
Old Sep 18, 2013 | 11:04 PM
use the search button
Old Sep 19, 2013 | 03:03 PM
ok i was able to find the info i need on everything except one question is 98,000 to many miles to be doing all of this?
Old Sep 19, 2013 | 03:06 PM
andrewcarr1993's Avatar
Only one real way to know, run a compression test and if their all about the same and at least 180 I'd say you're fine, milage really doesn't mean much when an engine is properly maintained but when it isn't is when you run into trouble.
Old Sep 19, 2013 | 06:48 PM
do a leak down test then get back
a compression test will not show the cylinder condition a leak down test will show cylinder condition and is an accurate test
Old Sep 19, 2013 | 06:52 PM
574's Avatar
574
x2
Old Sep 19, 2013 | 06:59 PM
ThexGovenor's Avatar
as mr b said. do a leak down. if it all checks out you will be fine. you arent pushing it too much with that setup. get the right tune and you will be fine
Old Oct 8, 2013 | 04:20 PM
hungryhip-ccp's Avatar
Hp
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
