HELP! With Cam Sensor
So i have tried and tried but i still get the camshaft code, I put the #4 cylinder at tdc and set the cam deal on with the mark lining up but it doesn't go in unless i rotate it another few degrees. fml
I would say your not at tdc then but could be wrong.
(My buddie had a spark plug drilled out with a shaft that slid in the hole that he used to get tdc)
Rotate the crankshaft until number 4 piston is at top dead center (TDC) on the compression stroke.
Refer to the crankshaft damper-to-front-cover timing marks.
Install the NEW camshaft position sensor housing seal.
Align the timing mark on the housing with the timing mark on the hex shaft.
Install the camshaft position sensor housing.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the camshaft position sensor housing studs.
Tighten
Tighten the studs to 22 Nˇm (16 lb ft).
Install the underhood junction block. Refer to Underhood Electrical Center or Junction Block Bracket Replacement .
Install the drive belt tensioner. Refer to Drive Belt Tensioner Replacement - Supercharger .
Connect the negative battery cable.
Tighten
my buddy who swapped his head multiply times on his lsj says its trial and error, I am swapping on my ported head soon, he told me to bring oil cause it spits some oil out the side everytime you get it incorrect, hope this puzzle of info helps at all lol.
