Help Camshaft Correlation Code
Old May 22, 2008 | 03:37 PM
*TRIX*'s Avatar
p0017
ehhhh i put the car back to tdc and everything back together and it takes like 123896189313 cranks for the car to start and me and paul tried to do a relearn and it didnt work correctly... anyone that can help me its worth a try
Old May 22, 2008 | 03:38 PM
Smarty Art's Avatar
Maybe your cam sensor is damaged.
Old May 22, 2008 | 03:41 PM
Josh@ottp's Avatar
your cam sensor is probably off by a flat or two
Old May 22, 2008 | 03:49 PM
*TRIX*'s Avatar
then how do i go about fixing this issue? do i have to unplug to battery and reset the motor to top dead center or bleh? iono really what to do
Old May 22, 2008 | 03:50 PM
Area47's Avatar
Rent me! per hour
set number 4 at tdc, there is a mark inside the cam sensor. line it up and stab it.
06black's Avatar
subscribed for later.
Old May 22, 2008 | 03:51 PM
Area47's Avatar
Rent me! per hour
wtfm8?
Old May 22, 2008 | 03:52 PM
*TRIX*'s Avatar
so i take the sensor and the back portion off and turn the motor till the mark meets up with what?
Old May 22, 2008 | 03:53 PM
06black's Avatar
i was hoping to find a pic-tore of said CPS marking...
no such luck.
Old May 22, 2008 | 03:57 PM
Smarty Art's Avatar
You guys need da Witt.
Old May 22, 2008 | 04:00 PM
06blackg85ss's Avatar
actually there is a pic of it on the www.gmtunersource.com page in one of te build sections.... shows you how to line it up
Area47's Avatar
Rent me! per hour
no, he need to set number 4 at tdc. unbolt the sensors. line up cam sens mark
Old May 22, 2008 | 04:14 PM
according to gm it's #1 at TDC. we shall see what happens, he's starting on it no
Old May 22, 2008 | 04:18 PM
06black's Avatar
the metion of proper oriantation of the CPS is there.
but no simple picture....
and btw paul, if you think i'm gonna look thro tunersorce for this info, your crazy....
Old May 22, 2008 | 04:19 PM
chapter 6 page 118
there you go
Last edited by 06blackg85ss; May 22, 2008 at 04:19 PM. Reason: Automerged Doublepost
Old May 22, 2008 | 04:28 PM
06black's Avatar
gah, i guess i'll look on the site.
if theres a picture there, i should be able to find it in the LSJ files at work here....i has every thing.
you guys check all of this?
Old May 22, 2008 | 04:38 PM
Area47's Avatar
Rent me! per hour
my info came from the gm tech site on the dealer computer
Old May 22, 2008 | 04:56 PM
INFE's Avatar
damn this is way out of my league......
Old May 22, 2008 | 05:04 PM
Area47's Avatar
Rent me! per hour
make sure said mark is not a scratch.
try number 4. i bet you win cookies
Old May 22, 2008 | 06:20 PM
its all good, was off by a hex. Car is back together and running fine again
Old May 22, 2008 | 06:39 PM
Area47's Avatar
Rent me! per hour
it's always the little things
Old May 22, 2008 | 07:17 PM
INFE's Avatar
Thats good to hear man!!!
Old May 22, 2008 | 07:43 PM
*TRIX*'s Avatar
yeah cars runnning finally and the build book helped alot and it was so simple to do. piston 1 just needs to be tdc and then you just take the back lobe off and thereare 2 points in which you can hold and jam a finger in there to hold straigh when your putting it in you need to make it so that the little notch on the opposite side is in the 4:30 to 5:00 area and now my car starts perfectly.
Old May 23, 2008 | 12:16 AM
2K5SS/SC?'s Avatar
Trix, here you go bro! Visuals and instructions FTW!
edit: I'm a day late a dollar short as I hadn't made it to page 2 yet! Here is the pics and info though for whomever else may need it.
Old May 23, 2008 | 12:23 AM
jimbos'ss's Avatar
hey thanks for the pic!
