Help Camshaft Correlation Code
p0017
ehhhh i put the car back to tdc and everything back together and it takes like 123896189313 cranks for the car to start and me and paul tried to do a relearn and it didnt work correctly... anyone that can help me its worth a try
actually there is a pic of it on the www.gmtunersource.com page in one of te build sections.... shows you how to line it up
yeah cars runnning finally and the build book helped alot and it was so simple to do. piston 1 just needs to be tdc and then you just take the back lobe off and thereare 2 points in which you can hold and jam a finger in there to hold straigh when your putting it in you need to make it so that the little notch on the opposite side is in the 4:30 to 5:00 area and now my car starts perfectly.
Trix, here you go bro! Visuals and instructions FTW!
edit: I'm a day late a dollar short as I hadn't made it to page 2 yet!
Here is the pics and info though for whomever else may need it.
